According to my research, towers are a great way to grow potatoes. As the plant grows, you add dirt. Roots will form on the now buried stem, and potatoes will grow from them. You can go quite a ways up doing this, which means less footage on the ground and more room for other veggies! Yum!
A side benefit to making this is that if you decide it was too much work to use again, or that you really only need one potato tower, these cylinders can also be used as composters.
Remove these ads by
Signing UpStep 1Gather Ye Supplies
- 1 - 10 foot roll hardware cloth (makes 2 towers!)
I am 5 foot 3, so if you are shorter, you may want the 2 foot width.
- tape measure
- wire cutters
- weights to hold the wire down & keep it from curling back(I used hubby's boots!)
- heavy canvas or leather gloves (keeps the hands from being sliced & diced by the wire!)
- zip ties
- newspaper
- dirt
- seed potatoes (mine sat around a warm kitchen for a 2-3 weeks, giving them a good chance to get
day before you will be planting them so a scab can form on the cut end.
They have a tower which stacks up. It also has holes in the side so you can put some of the stalks outside at all levels so that there is more foliage which means more potatoes can grow. It also comes with a polycarbonate lid to keep the frost off in the early weeks. It's a very good product that lasts a long time and works!
If that's not enough they also have a £500 competition for the gardener who produces the most potatoes in a tower in a year!
http://www.youtube.com/watch?v=14UrtVIj9K0
or at TeacherTube
http://www1.teachertube.com/viewVideo.php?video_id=220236&title=Garden_Experiments
I plan to run "The Great Potato Experiment of 2011" if you would like to be part of our investigator team, of follow the progress, please see http://chancefour.web.officelive.com
It would be wonderful to get to the bottom of this.
If you already have spuds that have sprouted eyes, you can cut the potato around the biggest eyes, and let them sit out overnight to scab over. Once scabbed, you can plant the eyes, thus getting more plants out of the potato. This is something that grandma did, and that I do.
Also, if you get a bag of potatoes that are still covered in dirt, then chances are good that the potatoes were NOT sprayed to retard growth. I've actually used these types with no problem. All I had to do was wait for the eyes to develop. You don't use ALL the eyes, just the biggest ones.
Something else: As I dug in my regular garden, some of the lovely fat worms that I found were transferred to the potato towers. I didn't fertilize the towers, but made sure to add some kitchen waste so the worms were fed. Their castings provide fertilizer, and they also keep the soil from compacting. You might want to try that if you build on concrete again.
I don't know that I'll be growing potatoes this year, but if I change my mind, I would love to participate in your experiment. Thank you for the invitation!
I wish I knew the official variety name of your reds and whites. This year I will get the seed potatoes from the seed company or garden store, then I will be able to idnetify the official name of the variety. I need to reproduce good results and identify and avoid the varieties that don't respond to the tower procedure. I would like people to be able to avoid an entire growing season that had no chance for success in the first place. It would be great for you to join us. I can't find any data on experiments of this kind.
Really liked your tater cage and will most likely give it a try. Was it hard to get the paper to stay in place? Would it be easier to wet the paper pages and sort of mold them to the cage while it's on it's side, then stand it up and put the dirt in?
The older I get the less patience I have with things that won't stand still and do what they're supposed to and my arms aren't long enough to reach down into the cage. I can't wait to get home and build some of these and thank you for mentioning the letting them rest overnight thing. I never knew and I'll check out the website about the potatos. Thanks again! Good luck with the subterranean critter invasion.
It is a bit tricky if you are trying to put the papers and dirt in by yourself, but it can be done. Here's how I'm going to do it this year:
FIRST I need to put a wire bottom on my potato tower. Setting it on the plywood was ok, but kept the beneficial worms away. With a wire bottom, it can sit directly on the ground with no fear of moles/voles getting in and allow easy access to worm.
SECOND: I keep the sucker shoots I cut off my filbert trees and use them to stake the papers up by sticking them into the ground inside the cage and against the sides. THEN I backfill with dirt. As the plants grow I add another panel of paper around the inside, again using the "sucker stakes" to hold them in place until I backfill more.
The HARDEST part is getting that first layer in, due to how tall the tower is and how short I am! I ended up bending the wire in at the top, but that's okay, as it bends out again.
Good luck!!
Thanks for stopping by, and be sure to check out my OTHER mole-proof cage!
Also, be sure to Google potato towers, and hit Youtube.com. There are some awesome video instructions on a variety of towers!
Finally? Good luck! Home grown potatoes ALWAYS taste better!!!
Basically, if the temp of the soil is 45 degrees F or warmer, it is safe to plant potatoes. Just protect them from frost if the plants are young. They require full sun, soil that drains well (too wet and all you get is rotten potatoes!) and is slightly acidic. You can plant as late as June 15, but check your zone.
DO be sure to use SEED potatoes and not the ones from the grocery store. Visit the site for all the pertinent info you need!
While the caging system is nice, simple, and clean looking.... I can get tused tires by the truckload for free. and Craigslist has been giving me all the topsoil I could handle(augmented by free alpaca-poo compost). It would just be so much easier, I think the neighbors will just have to put up with my "black garden plot". At least till I get some stone to make it look pretty. Next spring, I'll get an early start, and see if i can't go 6 layers deep in one growing season :-)
Thanks for the inspiration and knowledge.
