3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
POV on Basic Stamp
POV on Basic Stamp
I was surprised when I could not find any persistence of vision projects on the web using a basic stamp.
Initially I used a piezo speaker to beep each time the pov pattern was complete. This allows you to synchronize your waving motion with the message display. The final pov implementation uses a Memsic accelerometer to figure out when to reverse flash order.
Step 1Build the circuit
Build the circuit
I used the integrated bar LED DIP, but a row of single LEDs should work just fine.
14 comments
Sep 28, 2008. 12:29 PMAdamMunich says:
instead of 10 470 resistors on cathodes. use 1 on anode
Feb 11, 2010. 9:55 PMsam says:
I don't think that works, as the resistance required varies with how many LED's are being lit up.
May 22, 2011. 8:14 PMinsignia96 says:
This would likely work OK, the problem you would run into is that if you have instead of 10 resistors dissipating power (let's say 0.1W) you have 1 resistor dissipating all of it (1W total, would need a bigger resistor). But you're still right. There would be less consistency in the brightness.
Jun 8, 2008. 12:44 PMItsgoofytime says:
I agree. PIC is vastly superior to BASIC STAMP 2. The basic stamp 2 is overpriced, underpowered, and inferior to many microcontrollers out there. BASIC programming language teaches you bad programming habits that can sometimes make it hard to switch languages.
Jul 31, 2009. 2:18 PMruawake says:
Could anyone explain why you will not likely develop bad habits, like "go to", which leaves you with no trail of breadcrumbs. Does pic use python or list?
Jul 16, 2009. 2:42 PMzoltzerino says:
Picaxe
May 9, 2008. 11:08 PMEbay says:
(removed by author or community request)
Jun 3, 2006. 9:20 AMandreq says:
If you really want a cheap solution for starting with Pic : 1 - Get Pic sample from microchip (free but don't abuse) 2 - Get a cheap $15 serial pic programmer from ebay 3 - "find" pic basic programmer" to "try" it enjoy
Sep 9, 2006. 9:45 AMbotronics says:
You can make a programmer that uses IC-PROG (free) very cheaply with my Pic-Key programmer. Use Pic-Pro-Basic and cheap pics and stop using those $50 stamps.
http://home.comcast.net/~botronics/pickey.html
Jun 3, 2006. 12:54 AMandreq says:
If you ever feal like doing basic for pic... but don't want to blow up $40 on a ......... get yourself : PicBasic Pro Compiler (not free...but....anyway..) you actualy have many Basicstamp function in this...
Jun 2, 2006. 10:18 PMabbtech says:
Nice job, same idea as this one. Just minus the motor:
http://www.alan-parekh.com/rotating_display.html
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:WyoJustin(Justin Shaw)
