3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
POW-Rduino testing tool
Step 10COMPONENTS - install all components
MATERIALS NEEDED:
1 -- PCB - worked on in STEP 9
2 -- Diodes 1N4004
9 -- 2-Position PC board terminals
INSTALL DIODES:
Diodes are very important in this project.  The theory behind thier function can be explored at:
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=119
You must install them in the correct position or problems could surface during long term use of this tool.
Diode-1 (D1) needs to be inserted at these holes on the PCB:
Black End - inserted into hole location B11
Silver End - inserted into hole location K11
Diode-2 (D2) needs to be inserted at these holes on the PCB:
Black End - inserted into hole location P11
Silver End - inserted into hole location X11
INSTALL TERMINAL BLOCKS FOR PIN-5 (P5) & PIN-2 (P2):
Using 4 -- 2-Position PC Board Terminals (T) insert as follows:
TERMINAL-5 (T5)
RELAY-1 (R1) - at hole locations J9 / L9
RELAY-2 (R2) - at hole locations O9 / Q9
TERMINAL-2 (T2)
RELAY-1 (R1) - TERMINAL-2 (T2) at hole locations B9 / D9
RELAY-2 (R2) - TERMINAL-2 (T2) at hole locations V9 / X9
Using 5 -- 2-Position PC Board Terminals (T) insert follows:
TERMINAL-1 (T1)
RELAY-1 (R1)  & RELAY-2 (R2) - at hole locations L30 / N30
TERMINAL-4 (T4)
RELAY-1 (R1) - at hole locations F28 / H28
RELAY-2 (R2) - at hole locations R28 / T28
TERMINAL-3 (T3)
RELAY-1 (R1) - at hole locations A28 / C28
RELAY-2 (R2) - at hole locations W28 / Y28
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:rik
