Step 12INSERT PCB -- into outlet box
MATERIALS NEEDED:
1 -- PCB - worked on in STEP 11
4 - 10mm Insulated Standoffs
1/4OD X 1/8ID X 1/4 Tubing
ADD STANDOFFS:
Add 4 insulated standoffs to the bottom of the PCB. This will give support to the PCB once all the wires have been put into place.
TUBING POSITIONED:
Place 1/4" tubing over the mounting screw. This will allow for some give in the PCB as you position wires in the TERMINAL BLOCKS (T).
INSERT COMPLETED PCB:
Find the "T" mark you made in your box. Have that positioned away from you. Insert your PCB into the OUTLET box. Alpha letters will be on the right side. TERMINAL-1 (T1) will be on the left side. Line-up your mounting screw with the hole drilled in the plastic rise in the middle of the box. Make sure the short tubing stays on the mounting screw. Tighten the mounting until firmly in place and standoffs are firmly sitting on the bottom of the box.
Add Comment
