3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
POW-Rduino testing tool
Step 2PROJECT MATERIALS
PROJECT MATERIALS
A -- White OUTLET box
http://www.lowes.com/lowes/lkn?action=productDetail&productId=10029-223-E987N-CAR&lpage=none
B -- 1/2" Strain Relief Cord Connector - Lowes 6141127693 part number
C -- White Closure Plugs  (paint grey ones if needed)
        2 - 1/2 inch
        4 - 3/4 inch
D -- White Waterproof blank outlet cover - Lowes 70737 part number
E -- 3 prong power cord
F -- Foam blank to create hardware template
G -- RED and BLACK (20AWG) wire - 15 inches each
http://www.radioshack.com/product/index.jsp?productId=2049743
H -- BLACK AND WHITE - Primary Wire, 18 Gauge, 600V
        On all high voltage conections only use 600V wire -  will need 12 inches of each
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/113512/377%20710/0/wire/Primary%20Search/mode%20matchallpartial/10/0?N=377710&Ne=0&Ntt=wire&Ntk=PrimarySearch&Ntx=modematchallpartial&Nao=10&Ns=0&keyword=wire&isLTokenURL=true&storeNum=5002&subdeptNum=9&classNum=121
I-- air pump to test POW-Rduino or any equipment you want to use.
J -- Fully Insulated Mini 1-1/4" Alligator Clips - for testing conections
http://www.radioshack.com/product/index.jsp?productId=2062236
K -- Component PC Board - 750 solder-ringed holes
http://www.radioshack.com/product/index.jsp?productId=2103798
L --  Heat-shrink Tubing
http://www.radioshack.com/product/index.jsp?productId=2062662
M -- Diodes 1N4004  - Use 2 of these
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=1537918&
N -- OMRON ELECTRONICS - RELAY,G5LE-1 DC5 - you need 2 of these
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?jameco_page=42&langId=-1&productId=187151&catalogId=10001&freeText=omron+g5le-1&storeId=10001&search_type=all&ddkey=http:StoreCatalogDrillDownView
O -- Decorator Grounding Receptacle - Lowes 279490 part number
P -- Safety Binding Posts - will need 2 RED and 1 BLACK
http://www.radioshack.com/product/index.jsp?productId=2103639
Q -- Green LED with Holder
http://www.radioshack.com/product/index.jsp?productId=2062569
R -- SPST Lighted Rocker Switch - will use 2 of these
http://www.radioshack.com/product/index.jsp?productId=2062522
S -- Blank Outlet Cover - for practice to drill holes in advance of actual drilling of holes.
T -- Arduino and battery supply
U -- Bread Board for sensor input circuit
PARTS NOT VIEWED IN PICTURE:
2-Position PC board terminals
http://www.radioshack.com/product/index.jsp?productId=2102861
10mm Insulated Standoffs
http://www.radioshack.com/product/index.jsp?productId=2102860
1/4OD X 1/8ID X 1/4 Tubing
Connector Nut -  Lowes 000000 part number
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:rik
