Step 5Outlet Box Assembly
MATERIALS NEEDED:
1 -- White OUTLET box
http://www.lowes.com/lowes/lkn?action=productDetail&productId=10029-223-E987N-CAR&lpage=none
1 -- 1/2" Strain Relief Cord Connector - Lowes 6141127693 part number
White Closure Plugs (paint grey ones if needed)
2 - 1/2 inch
4 - 3/4 inch
Power cord constructed in Step 3
5/8" drill bit
DRILL CORD ENTRY HOLE:
Using the 5/8" drill bit - drill hole in the Box bottom 1/2" inlet plastic.
STRAIN RELIEF CORD CONNECTOR (SRCC):
Locate your strain relief cord connector
BREAK APART THE STRAIN RELIEF CORD CONNECTOR (SRCC):
The SRCC unit will break out into 3 different parts. Make sure to keep track of the correct end on the center part of the unit.
ATTACH SRCC BASE PART:
Take the SRCC base part (one with the male threads on it) and screw the more course threads into the 1/2" inlet (the one with the see through hole). It was created at the start of this step.
POWER CORD WITH SRCC PARTS:
Using the power cord created in STEP 3 run the stripped 3 wire end of the power cord through nut part of the SRCC. Continue by running the stripped 3 wire end through the nylon water proof bushing (big end on the plug side of the cord).
POWER CORD GOES INTO BOX BASE:
Feed the stripped 3 wire end through the SRCC base part and into the inside of the box bottom. Pull about 1/4" of power cord passed the end of the SRCC base inside the box.
TIGHTEN SRCC NUT:
Hold the 3 stripped wire end in place and tighten the SRCC nut to the threaded male base connector attached to the base of the outlet box.
CLOSURE PLUGS TO COMPLETE STEP:
Use closure plugs to cap all unused inlet holes on the box.
Should be as follows:
1 - 1/2" on back of box
1 - 1/2" top of box
2 - 3/4" top of box
2 - 3/4" bottom of box
Add Comment
