Step 9RELAY MOUNTING - on PCB
1 -- PCB - worked on in STEP 4
2 -- OMRON ELECTRONICS - RELAY,G5LE-1 DC5
1 -- 3/64" drill bit
RELAY MOUNTING:
RELAYS need to be mounted on to the PCB. In order to keep both RELAY PIN-1 (P1) close together you have to reverse RELAY-2 (R2) it controls OUTLET-2 (O2). When done correctly both PIN-1 (P1) of the RELAYS will be facing each other.
PROBLEM:
RELAYS will not go into the holes on the PCB as configured.
FIX THE PROBLEM:
RELAY-1 (R1) - needs to be positioned as follows:
PIN-1 (P1) - between I16 / I17 and J16 / J17 holes
PIN-2 (P2) - in hole I14
PIN-3 (P3) - in hole D14
PIN-4 (P4) - in hole D19
PIN-5 (P5) - in hole I19
RELAY-2 (R2) - needs to be positioned as follows:
PIN-1 (P1) - between P16 / P17 and Q16 / Q17 holes
PIN-2 (P2) - in hole Q19
PIN-3 (P3) - in hole V19
PIN-4 (P4) - in hole V14
PIN-5 (P5) - in hole Q14
Using the top side of the PCB make a square marking between holes I16 / I17 & J16 / J17 holes. Make the same type of mark at P16 / P17 & Q16 / Q17 holes.
In the center of the square marking formed by the holes drill a 3/64" hole in each square marking.
PIN-1 (P1) on each RELAY will now have a hole to rest in.
PROBLEM FIXED:
You can now insert the RELAYS in to the correct holes and the RELAYS will sit flat on the PCB.
RELAY-1 (R1) MOUNTED:
insert RELAY-1 (R1) into the following holes
RELAY-2 (R2) MOUNTED:
RELAY-2 (R2) will be reversed from REALY-1 (R1) and PIN-1 (P1) of each RELAY will face each other.
KNOW YOUR RELAY PINS:
Now that the RELAYS are in place you need to know PIN locations on the back side of the PCB.
Add Comment
