loading
PROJECT POWER BANK SOLAR - PORTABLE
POWER OUT TOTAL - 140W RMS - 110/220AC
MAX load Ia = 2,4a
AUTONOMY - 4 HOURS - USE BATTERIES 12V 7Ah in parallel
use:
CHARGE NOTEBOOKS
TV´S
PRINTERS
RADIOS
DVD´S PORTABLE
DVD HOME THEATER´s
LAMPS 12V
itens
1 - PAINEL 40W to 60w - ANY MODEL -
1 - CHARGE CONTROLLER - ANY MODEL
1 - INVERTER 1000W/1500W PMPO - 12VCC - 110/220AC
2 - BATERIES 12cc - 7Ah - GEL VRLA
CABLES
SWITCH
FUSE
GLUE
Step 1: DIAGRAM UNIFILAR
Step 2: CHARGE CONTROLLER
This controller is possible conect inverter
Step 3: BATTERY
BATTERY GEL
ANY MODEL 12 V 7Ah or more, with 7Ah in parallel, autonomy 4 hours night
Step 4: USE POWER BANK
Step 5: PV MODEL 40W TO 60W
This model panel KYOCERA KC50T 54W
Step 6: CONNECTION CHARGER
Step 7: CONNECTION 2
Step 8: Shwitch
Step 9: PLACE BATTERIES AND INVERTER
<p>I would not connect the inverter to the controller, it will burn out the controller. Instead install 12v relays to drive the inverter</p>
<p>Gilbderto</p><p>thank you, really can , but I tested this driver(charger controller) and is working perfectly, because the controller does exactly this function by monitoring the load.</p>
<p>Gilbertok is correct. You are not supposed to connect an inverter to the load control of a charge controller. It might be working ok for you for now, but if a larger load is plugged into the inverter and it pulls more amps than the charge controller can handle, it will blow up the charge controller. Connect the inverter straight to the battery through a fuse or breaker instead. Most inverters have low voltage disconnect already and don't need to go through the load control on the charge controller.</p>
About This Instructable
1,743views
30favorites
License:
More by JuarezG:      Wireless - omnidirectional antenna Plus +10Db - Antena Omni Potencializar SUPER LED LAMP - LUMINÁRIA LED EQUIVALENTE 150W POWER BANK SOLAR - PORTABLE
Add instructable to:
