Introduction: POWER PACKED LED FLASHLIGHT
INTRO:-
This is a very powerful Flashlight that turns night onto day at a radius of 100 feet.
It uses 60 Bright White LED’s with a Rechargeable 6 volts 4.5 Amps leak proof lead acid
Step 1: Step-1
Items you will need are:-
One old Flashlight casing to assemble the light.
60 Bright White LED 5mm
One PVC round base to fix the LED’s.
60 Resistors of 100 Ohms ¼ watt.
One 6 Volts 4.5 Amps Rechargeable Lead acid
One On Off switch.
Wires, Solder, etc.
Step 2: Step-2
Follow the Circuit Diagram and fix the LED’s on to the PVC base.
Care is to be taken to maintain the POLARITY of the LED’s.
The PLUS side is Positive and the MINUS side is Negative.
The Resistors should be soldered on the Negative side of the LED’s.
The on / off switch should be on the Positive side.
Step 3: Step-3
Fix the
Assemble the whole circuit and fix it in the Flashlight casing.
Step 4: Step-4
Your Power packed Flashlight is now ready.
Switch on and Enjoy.
Finalist in the
Flashlight Contest
