Remove these ads by
Signing UpStep 1Decide on your design
This WHOLE mod is centered around a single design. If this is your very first mod to a console, or if you aren't very skilled with a dremel, you should consider a simple shape, such as a rectangle, circle or triangle. Simple shapes are MUCH easier to do than complex ones (obviously)especially if you rarely work with a rotary tool, such as a dremel. Try not to choose a design that exceeds your skill level. Simple designs look good, especially if you take your time. Something like this should be easy enough.
Tools:
rotary tool(dremel)
exacto knife
brain
Materials:
Ps2 case
clear cd case
Fasteners(rivets,screws,glue,etc)
Philips Screwdriver
Flathead screwdriver
Design Template(detailed later on)
Another good instuctable using this method is Here
http://psx-scene.com/forums/attachments/ps2-case-modding-customization/6518-help-led-ps2-please-solderpoints.jpg?d=1107212973
it's 12v so It will need a resistor, how hard was it to set them up with the fans power source, as now that seems easier than ripping the whole thing apart and putting my (very poor) soldering skills to use on the board.
