Flash Drive in a Memory Card (PS2)
This Instructable is about how to put a usb flash drive into a Memory Card's case. It isn't very hard and so it won't take you more than about 15 Minutes. This is my first Instructable, so please let me know what you think about it!
Step 1Opening the Memory Card
For this little project you'll need:
1 Memory Card
2 Flash Drive
3 Screwdriver or knife
4 Dremel or a rasp
5 Sticky tape
At first you have to remove those tiny screws on the backside of your Memory Card to open it. If you don't have a fitting screwdriver just use a knife or something else.
49 comments
1-40 of 49next »
May 30, 2011. 3:31 PMdmazzo says:
Thanks for this man! The case on my USB drive fell off the other day. I wanted an easy way to add a new cool case. It just so happens that thursday I took a PS1 memory card to GameStop and they wouldn't take it. So I used that.
Sep 26, 2010. 6:29 PMplanebuilder123 says:
that is a pretty cool usb stick
Aug 1, 2008. 12:52 PMhvac2010 says:
....Thanks im accually tryin to build a computer out of a ps2 case and want to keep it as original looking as i can....this is perfect!!!! now i just have to modify the memory card slot so it'll works thanks....
Oct 17, 2008. 5:05 AMthepaul1993 says:
you would have to use the old ps2 what i want to do is get a really old laptop (the first ones) and upgrade it to the MAX!
Aug 21, 2010. 7:15 AMmason0190 says:
Epic OverClocking!!!!!!!!!!!!!!!!!
May 24, 2010. 2:14 AMEarths_hope says:
ZIGGY BOOGY DOOG
Sep 16, 2008. 7:22 AMBartboy says:
simple thing, just get a mac mini and but it in a ps2 case! TA DA!
Aug 15, 2008. 6:52 AMdavidprosser says:
You could keep the memory slots how they are, strip the insides of memory cards, put inside them a USB flash drive but remove the USB plug, solder the connections of the card to where the USB plug should be, and wire the PS2 case memory card slots to be USB. If you get me - I'm kinda getting carried away! I could probably make you a diagram if you want. But there are USB sockets on the PS2 anyway so there isn't much need. The other option is to simply buy one of those cheap Playstation controller to USB adapters like this one, then you can even use the playstation controllers for games if you wanted and connect the USB internally. I could keep thinking of stuff but I need a break now. It's been a while since I did a project like that.
Aug 15, 2008. 10:05 AMhvac2010 says:
..ya i kinda git u but a diagram would be nice....
Aug 16, 2008. 2:24 PMdavidprosser says:
OK lol here are diagrams of putting USB keys inside of a Playstation memory card and also another diagram for keeping the controller sockets how they are and using them for game pads as PS2's have USB anyway. The diagrams are messy but I hope they can help! Of course if you just wanetd to use your PS2 as a computer, have a look at this, which is a kit to run Linux on your playstation.
Aug 17, 2008. 9:48 PMhvac2010 says:
thanks for the diagrams...and i had looked into the linux converstion before. its acually what gave me the idea to do this but i want it to run xp. thanks again.
Aug 18, 2008. 5:10 AMdavidprosser says:
Cool. One thing you will need to check out is how it's all going to fit in there! I mean personally I don't own a PS2 but a few of my mates do, and I found a knackered one on eBay for about £10/$20 which I might buy just to experiment with. Also you may have trouble fitting the power supply for the PC in there, so I thought that it might be best if you used the insides of a laptop as they are already compact. Otherwise a mini-atx motherboard and mini-atx slim PSU unit may work.
Aug 22, 2008. 2:00 PMhvac2010 says:
ya it took me a while to rind all the parts im gona need and i think i know what im gona git but im still trying to git the money....ins still desiding between a laptop and regular cd drive i need to figure out how to use the original ps2 eject button on a slim cd drive that would be helpful if some one could help...i really dont have a guide to go on so it will take some work....
Aug 5, 2008. 11:07 AMtubbychick3n says:
sounds like it could be interesting. upload pics when it's finished.
May 24, 2010. 2:13 AMEarths_hope says:
Nice, the memory card is a ps2, then a ps1 mem card
Aug 27, 2009. 7:10 AMzimmemic25 says:
nice instructable, but the title suggests the possibility of using flash drives for PS2...
Aug 26, 2009. 2:27 PME_MAN says:
I like it! But it seams strange, take apart one type of storage to make another. It does look cool.
Dec 10, 2008. 6:10 PMsergentslaughter says:
in half the pics the memory card is blue then in the other half of the pics it's black
Dec 11, 2008. 8:18 PMsergentslaughter says:
dude you don't have to apoligize im just busting your balls....
Dec 12, 2008. 2:37 PMTrogdor_The_Burninator says:
Ahahahahaha... I lol'd at "im just busting your balls..."
Jun 12, 2009. 11:47 AMmatrix828 says:
lol me to
Jan 10, 2009. 1:28 PMjose1980 says:
what i was really looking for is a way to use the usb sockets of the ps2 to save game data. why would i want to put a usb drive into a memory card case? thanks anyway. If you can help me with my case, I,d really appreciate it.
Mar 12, 2009. 4:43 AMcornflaker says:
Its the same as putting a flash drive in a cork, apple, altoids tin, duct tape, zippo, eraser, lego block... Because it looks cool lol
Aug 12, 2008. 12:35 AMkazmilk says:
Why?
Jul 22, 2008. 12:50 PMGrey_Wolfe says:
I enjoy the creativity of this. But I wonder why one would want to do it? PS cards are larger than most flash cards, which kinda takes away from the point. I mean, it makes sense if your flash case is compromised/broken. What if, maybe, it was retractable? Then it would serve a stealth purpose, as currently, someone is less likely to swipe you memory card than your flash drive? Don't take me wrong, I think it's cool. It just doesn't seem to have much extra purpose, and I was wondering your motivation behind it.
Jul 29, 2008. 10:56 PMhinata1001 says:
Ok not sure if you would know but could one use this memory card to plug into the computer and transfer files to it -being the memory card.- such as gamesaves or something.
Jul 31, 2008. 4:35 AMGrey_Wolfe says:
As the usb flash card, you can (IRC), but you might need to have a hard drive installed in your PS2 in order to access the card, haven't tried it. Or have something like an AR (Action Replay) disc. My AR actually came with a USB drive so that you could update codes, and download saves. It would allow you to transfer the saves to the PS memory card. I had to use the AR to access it, but that may have been simply the way the card was formatted. I may be a bit off on this though, the PS2 comes standard with usb slots, so I'd think you should be able to use a flash card in it, but I just haven't gotten around to messing with it too much. That was probably more of an answer than you were asking for. Sorry 'bout that, but I hope it helps.
Jul 24, 2008. 7:56 PMberky93 says:
I just had a cool idea - what if you cut off the part of the memory card that fits into the play station and kept it for use as a cap. that way it would look like a regular memory card (not a flash drive) when youre carrying it around and when its in use it would look as if you actually inserted he memory card into the computer
Jul 25, 2008. 9:39 PMberky93 says:
maybe one of those pico thumb drives... I'll give it a try some time, seeing as I never use all of my playstation memory cartridges (I use 1, rarely)
Jul 24, 2008. 2:18 PMCannonwood says:
All for giving an alternative life to something out of date - I've some old USB memory drives that still work but are just 'small' and am looking for ideas (like this - thank you!) to make them quirky, jazz them up, some how bend them at a right angle and dress them up in hula skirt, get them to flash their little lights, glow in the dark, twirl, self eject - anything. They still are usable.
Jul 24, 2008. 12:51 PMdudeguy1234 says:
Looks like my Flash Drive Instructable, only mine was put in a figure or Han Solo in Carbonite :)
Jul 24, 2008. 12:53 AMrs2king says:
lol i did the exact samething as this a week ago but i used a ps1 memory card i even used the same type off tape lol you dont live in new zealand by any chance do you?
Jul 21, 2008. 1:15 PMJohn Smith says:
can you use the memory in the ps2 usb slots?
Jul 21, 2008. 6:05 PMironsmiter says:
yes and no. definately yes, if you've got the linux kit installed. Possibly, depending on the thumbdrive, and mods made to the ps2. Stock ps2, no, and WHY woould you want to? If you're careful, and protect the board, the memory card can still be used normally, even after being de-cased
Jul 21, 2008. 8:39 PMJohn Smith says:
Stock ps2, no, and WHY woould you want to? memery card: 8mb flash drive:>1gb
Jul 23, 2008. 5:44 PMironsmiter says:
gheesh, how many saved games do you HAVE? Sorry, I just don't see it. My 16MB card didn't fill up in all the years I had my PS2, and I played a LOT. Is there a game that takes huge amounts of save-game space?
Jul 23, 2008. 5:59 PMJohn Smith says:
ha, no. i havent played PS2 in years. ok, a few months. i'm not into games much. but i always rememebred out 8mb card getting filled up. might just be me though.
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:MrUniverse
