All measurements are inside diameter.
I WILL UPDATE WITH NEW PLANS EVERY NOW AND THEN.=)
I'M NOT RESPONSIBLE FOR ANY DAMAGES OR INJURY'S CAUSED BY YOU FALLOWING THESE PLANS
All Steps Viewing
will give you over a hundred pounds of thrust and LOTS of noise. Ear protectors are a must even with the small ones.
Check it out.
So, in summary, you light off an explosion in a can with two holes. If both holes are pointing the same direction, you get more thrust. After the explosion, both holes act as an intake (one hole has a shorter tube, allowing it to be the primary intake). Then the explosion is ignited again, and the process repeats. There is no continuous flow of air through the engine as there is in a Turbojet or a Ramjet.
Hope that cleared some things up,
-Bob
This design is basically one of the U-shaped designs, unbent for ease of construction.
-Bob
Post Scriptum: See http://www.pulse-jets.com/ for a better explanation than I am able to give.
Similar to the standard valveless lockwood pulsejet.
http://www.aardvark.co.nz/pjet/mylockwood.shtml
The main difference is that the lockwood's two jets face the same direction, which will increase thrust. Nice plans
