Step 2Add a flex sensor
-Adjust Analog input values so everything works right with the flex sensor. It is okay to guess a little
-Here's the updated code
////////// Arduino Code ///////////////
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott
//MPC - added serial output 'n stuff
// With flex sensor
// -Tweak Val to Angle Map
Here is the wiring:
Wiring -
Flex Sensor |------Arduino Gnd
Flex Sensor |------Analog 0
100K |------Analog 0
100K |------Arduino 5V
| Yellow ------ Digi 9 (PWM)
Top servo | Red -----------5V
| Brown -------Gnd
| Yellow ------ Digi 10 (PWM)
Bottom servo | Red -----------5V
| Brown ------
#include
Servo myservo; // create servo object to control a servo
Servo otherServo ;
int potpin = 0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
int valComp;
void setup()
myservo.attach(9); // attaches the servo on pin 9 to the servo object
otherServo.attach(10);
Serial.begin(9600);
void loop()
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
Serial.println(val);
valComp = analogRead(potpin);
val = map(val, 40, 350, 90, 179); // scale it to use it with the servo (value between 0 and 180)
valComp = map(valComp, 350, 40, 0, 90); //other servo does oposite
myservo.write(val); // sets the servo position according to the scaled value
delay(15);
otherServo.write(valComp);
delay(25); // waits for the servo to get there
Add Comment
