This is a European style stand with no adjustability & no rotation of the bike. But it also requires no clamp & has no moving parts. It can be used to do mechanical work, wash your bike, or for storage & display.
This stand suites my style in two very important ways. First of all, I enjoy mountain biking & doing my own wrench work. Second of all, I hate to spend a lot of money on something that should perform a very simple function.
Remove these ads by
Signing UpStep 1Materials & Tools
Tools:
- hack saw (or alternately a PVC tubing cutter)
- tape measure
- wood chisel (or alternately a dremel tool with a carbide bit)
- pencil & dry-erase marker
- file
- sand paper
PVC parts:
(4) 15" lengths of 1 1/2" diameter pipe for the base supports
(2) 34" lengths of 1 1/2" diameter pipe for the legs
(1) 16" length of 1 1/2" diameter pipe for the down-tube support
(1) 51" length of 1 1/2" diameter pipe for the base outrigger
(1) 3" length of 2" diameter pipe for the bike rests
(3) 1 1/2" T-fittings
(2) 1 1/2" 90 degree elbow fittings
(2) 1 1/2" coupling or end-cap fittings
(1) 1 1/2" cross fitting (AKA 4-way fitting)
Other materials:
- PVC cement (get the cheapest kind, since it doesn't need to hold water)
- 1 1/4" rubber foam weather stripping (optional)
The 1 1/2" pipe pieces total just over 16 feet. I bought (2) 10 foot pieces & used most of the excess 4 feet on design mistakes so that you don't have to. You could make the legs & base parts a bit shorter, but then you'll be doing a bit of bending while working on your bike. At these lengths, you can do most of your work fairly upright, but the stand is still sturdy & you can fit it through most doorways if you want to move it from room to room or outdoors.
If you're not too concerned about asthetics, the printing on the pipe should not be a problem. If they bother you, you can buy PVC pipe without printing on some internet sites. But it will be more expensive - especially with shipping. You can even get PVC in designer colors. But if I wanted to pay that much I'd probably be buying a stand instead of making one.
Thanks
http://www.yourmtb.com/story/build_your_own_bike_repair_stand_for_under_20
it might be safer to
and if you make the bottom bracket support more of a circle eg higher sides so its tighter around the bottom bracket you could then maybe use something to tie it down
just some suggestions
but i really like it good job i can see lots of potential in it
thankyou
matthew
