Step 7Final Check
If your bike is top-heavy, you may find that it is a little tippy in the workstand. This is especially true if you need to apply some force while working on the bike. If you remove the wheels, the center of gravity is higher & the bike is more tippy. I'm trying to find a way to lend more stability to the bike with some kind of attachment. Perhaps I'll add some more information later.
http://www.yourmtb.com/story/build_your_own_bike_repair_stand_for_under_20
it might be safer to
and if you make the bottom bracket support more of a circle eg higher sides so its tighter around the bottom bracket you could then maybe use something to tie it down
just some suggestions
but i really like it good job i can see lots of potential in it
thankyou
matthew
