Introduction: PVC Bike Mud Guards for 2 Dollars
Winter is staring down in here in south hemisphere and i like to use my bike to go places near my house. So the idea was to spend as less as posible to add mud guards to my comuter bike.
My english is not the best, but i'll do my best to be clear.
Step 1: Materials and Tools
the list of materials i used were:
75mmx1m PVC sanitary tube
1 screw and nut
4 cable ties
Tools
Electric Saw
Gas torch
Dremel
others:
i recomend the use of safety glasses and gloves.
of course you need a bike to mount them and depending on the geometry and accesories of the bike the result and procedure may vary.
Step 2: First Step
1) cut the Tube tu have two half tubes
i chose a 75mm (3")  tube since the tires i use are 2" wide (50mm)
so measure your tires before you buy.
Step 3: Curved Mud Guard
for the rear wheel i wanted a curved mud guar.
so i messured the leght of the area that was going to be covered by the guard.
and cutted one half tube to that leght.
After doing so, i made parcial cuts to the tube so bending it where easier.
Then i heated the tube with the torch so the form i gave the tube remains in time.
then a few holes and cable ties and screws and you are done.
SEE where you can use screws or ties before you make anything!
Step 4: Front Fender
bending the tube is complicated.
so i prefered a straight tube for the front fender
you have to make 4 holes for the ties
i bended  the corners for safety, with the gas torch.
Step 5: End
If you experiment a lot with the materials and try to heat and bend everithing is goig to take you 2 hours. if you don't, it's much faster may be less than an hour.
I hope it helps!!
matias
