3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC Boot Warmer
PVC Boot Warmer
Keep your boots dry with PVC pipe, fittings and a hair dryer
Step 1Materials
Materials
3 -1.5 in 90 degree elbows
1 - 1.5 in cross
1 - 1.5 in cap
1 - 1.5 in to 2 in adapter
2 - 1.5 in PVC pipe 13 in long
5 - 1.5 in PVC 3 in long
1 - 2 in PVC pipe 5 in long
Hair dryer
Tools
Box saw (or other saw to cut PVC)
MIter Box
Drill
Optional
PVC Solvent
PVC Cement
8 comments
Feb 9, 2009. 11:13 AMPS118 says:
Good idea, but one little problem. Most (all?) hardryers have a thermal fuse to prevent them from overheating. Once airflow is restricted, the air backs up, heats the unit, and *poof* it stops.
(I toasted a couple of em that way growing up.)
Maybe if you drilled enough holes in the pipe so it can get enough airflow iyour idea would still work tho...
Sep 2, 2011. 3:25 PM1ofakindwork says:
Or you could cut the pipe at a sharp angle so the boot doesn't stop up the ends. I would also put a few slit from top to bottom on the pipes also this way it will blow out the sides too.
Feb 12, 2009. 2:56 PMsdallesasse says:
you could also add some electrical PVC of the same size. That would give a better fit for your boots. It would fit more like the commercial ones. And you still could drill holes in it to allow for more air distribution. Also you may want to add a box to house a very low wattage heating coil, the heat would cause a convection draft which in turn would provide a warm airflow into the shoes / boots. This also would cut down on the noise factor and you would not have to worry about burning out your hair drier.
Feb 9, 2009. 1:56 PMshooby says:
The solution to blockage of the pipes, is to eliminate the vertical elements. Just put the boots on the floor, so that hot air is pumped in, but the weight of the boots doesn't block the opening. Save on materials and size.
Feb 9, 2009. 10:10 AMlue42 says:
Nice idea... but wouldn't the airflow be restricted by the weight of the boot/shoe pressing down on the end of the tube? Perhaps a bunch of holes drilled around the end of the tube would be good for spreading the hot air around?
o o o |
o o |
o o o |
Feb 9, 2009. 10:11 AMlue42 says:
Whoa... that ascii drawing didn't turn out... but, hopefully you get the idea
Feb 9, 2009. 6:19 AM21GeeOff21 says:
cool nice and simple
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:nasmatt
