3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC Bow
This instructable has been removed by the author.
62 comments
1-50 of 62next »
Dec 27, 2010. 3:52 PMcap n crunch says:
cool ible but the notches on bows are called nocks anyways thanks for sharing
Oct 23, 2010. 6:11 PMGATEBOYNXT says:
This is an awesome bow! Just are there aiming notches?
Aug 5, 2010. 6:05 PMfalcon153649 says:
will the pvc pipe lose its spring power over time??
Aug 6, 2010. 7:01 PMfalcon153649 says:
will the pvc pipe shatter? cuz i heard that i will....
Feb 28, 2010. 9:27 AMfirefighter1333 says:
how far does YOUR bow shoot? pls reply
Mar 14, 2010. 3:31 AMfirefighter1333 says:
but, can it like shoot an arrow through both  sides of a cardboard box? (btw doesn't matter if u answer late, i'm happy with all answers i get)
Mar 18, 2010. 8:31 AMfirefighter1333 says:
hahaha lol ok
Mar 20, 2010. 2:57 AMfirefighter1333 says:
i am goin to make one soon with an wooden handel :D
Apr 6, 2010. 11:13 AMfirefighter1333 says:
finished about a week ago, it shoots 100/200 yards (when shot correctely)! it has a metal handle with a bound peice, it is AWESOME! ty so much!
Aug 5, 2010. 8:12 PMMikedood says:
Can you post a pic of it? It sounds awesome!!!!
Aug 10, 2010. 7:55 AMfirefighter1333 says:
sry, it's a long time ago: i alrdy made other projects of it, i do still have the bound metal piece though...
Jun 8, 2009. 5:05 PMsaberscar says:
feralin, there are different kinds of "real bows". Only in the newer bows do they have an arrow rest. In almost all old bows they were self arrowed and yeah, you rest em on your hand. This style is my favorite actually because you can hand the bow to anyone (bc im a lefty) and they can shoot it if they're a righty. But yeah, its good to know a bit of history before you bash someone. You are right though, in newer style bows, there is an arrow rest. But if you'll notice, these are lotr styled bows. Old bows. Great instructable man, i intend to make one. Thanks again X3
Feb 8, 2010. 11:52 AMsaberscar says:
Hey man, finally got my hands on a length of good pipe. Mine was CPVC its a little more resilient to bending and it shoots great! I used the orange twine they used on my Xmas tree X3 what you can do to make a good string from twine like that is get a length twice that of what your string will be and then fold it in two around a pole or something (i used a desk leg) so its the length it will be. twist one end clock wise, twist the other counter-clockwise. Then when both ends are tightly twisted, twist the two together clockwise. Tie the ends into bowlines and attach it to your bow :3 it works great. I tried using a single strand twine and it unraveled in a few hours of shooting. this one's lasted me all week. :3 Thank you!
May 8, 2009. 3:39 PMferalin says:
what do you put the arrows on? your hand? in real bows there is a little place cut horizontaly out of bows to put the arrow in when you are pulling back the bow
Nov 1, 2009. 4:51 PMSierra 117 says:
Epicness! truly amazing.
Jan 11, 2010. 3:21 AMiMakeRandomStuff says:
 made some mods, shot it about 20m accurate, at 45 degree angle, around about 60 metres.
do i love this bow. thanks for the instructables!
Jul 23, 2009. 1:08 PMorangewolf22 says:
gorgeous
Jul 14, 2009. 4:05 AMdaveisgreat says:
do you need something to guide the arrows so they dont go way off course or is it right without a guide
Mar 25, 2009. 7:19 AMknex gun instructions says:
what kind of string did u use?
Apr 13, 2009. 1:30 PMmannyboy446 says:
cool just made one do u know how to make arrows??
Feb 9, 2009. 1:52 AMoric11 says:
how about the arrows??
Nov 8, 2008. 2:07 PMbuster27 says:
this is the best pvc bow instructible i have seen yet
Jul 14, 2008. 9:41 AMWolfsire says:
Im a noob bowyer, and I know that this is more of toy than a serious weapon, but it is a real weapon and some times you have to make do with what is available. In the interest of the art/science of bowyer can you provide a draw weight? Here is how to do it. Draw the bow back as far as you would to shoot and have someone measure the distance from the bow to where you are holding the string. It will probably be between 15-30". Then get a heafty stick with a notch on one end (you can tape), that is longer than that distance. Mark that distance on the stick from the notch. Put the string in the notch (or tape it) and put in on a bathroom scale with the notch on top and note the weight- maybe 1-5 lbs. Then pull the bow down to where you have marked and note the weight. It might be anywhere from 10-50+ lbs. Id guess about 15 lbs. Be careful the stick does not slip with you do this. This is one way bows are measures, for example I have a bow that is 35 lbs at 20 inches. Id like to know about what 5'10"x1" pvc pulls. Also, how far will it shoot? It get an idea of how efficient the bow is you need to measure the arrow weight, but unless you have a postage scale, or something that can measure grains, grams or fractions of an ounce, you cant be accurate, and distance is a good indicator. Thanks. I look forward to seeing the stats. Oh, yeah. Glad to know about the tape. I have duct tape around my fiberglass x-bow prod as that stuff can shatter too, though it is regularly used for bows.
Dec 29, 2008. 5:40 PM15zhangfra says:
can u post an ible on this, i dont relly get it and want to measure my bow
Nov 9, 2008. 2:26 AMjasontimmer says:
I use a PVC bow for measuring arrows prior to cutting. They have a draw weight of about 8 pounds.
Nov 9, 2008. 3:04 PMcowscankill says:
How far would that be? or how far could it go...
Jul 14, 2008. 4:41 PMresonanteye says:
I wish I could figure out how to weigh that from this. you ought to write an instructable just for that, with some pictures
Jul 13, 2008. 5:12 PMTrans_Am says:
I'd be mighty careful not to over-bend a PVC pipe, since they are known for sending sharp pieces of plastic flying across the room when they break.
Oct 22, 2008. 10:25 PMnat_rigg says:
if your concerned about shards of PVC flying about, try wrapping the whole (or most) of the bow with electrical tape, or other similar tape, and if it does shatter, the tape should stop bits flying about, kinda like putting tape on windows during hurricanes, cyclones etc.
Jul 23, 2008. 7:39 AMbarnes says:
I second this comment...I'd avoid using PVC for a bow...I feel this Instructable is going to end up hurting someone eventually....
1-50 of 62next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:lotrsam11
Well I'm on here so i can leave people comments with pictures of the things i've made. Also, i love to build things!
