3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC Camera Mount
PVC Camera Mount
PVC is a great material. It's like Tinker Toys for adults. You can use it to build greenhouses, furniture, musical instruments, kayaks, toys, and yes, even plumbing. I thought it would be a great material for building low-cost camera equipment; the only problem is how to connect the PVC to a camera. This is the method which has worked well for me for the past couple of years. Once you build this one device, you're only limited then by your imagination!
If you like my design, feel free to vote for me in the Digital Days photography competition!
Here's the video version:
Step 1
Gather the Materials:
This is the hardest step of the project. I found all these pieces easily, but I've been informed that they aren't available everywhere. A bit of footwork and possibly ordering online should get you all these parts.
Hardware:
three ¼ inch hex nuts
one ¼ inch lock washer
one ¼ inch regular washer
one ¼ inch x 1 inch fender washer
one ¼ inch x 2 inch bolt (threaded the entire length)
PVC:
¾ inch schedule 40 end cap (flat)
½ inch schedule 40 plug
one inch of ¾ inch SDR Schedule 21 PVC pipe
Note that the PVC pipe is NOT Schedule 40. This pipe has 1/16 inch walls, as opposed to the more common Schedule 40's 1/8 inch walls.
5 comments
Mar 25, 2010. 2:52 AMguy90 says:
 Thanks for the upload, very informative! *thumbs up*
Oct 13, 2009. 5:25 PMGreenish Apple says:
Hi Paco!
I've just recently watched all your videos on YouTube, neat, innovative and fun! Great ideas. You got my vote.
Only one concern, will the camera fall off if you tilt the support/pods(s)? What if you drill a hole thru the Camera Mount and the support (not thru the middle but offset) then use a hitch pin to hold it on? You could tie a pin to each support with a string or wire.
David
(Afraid of dropping my $$ camera)
Oct 11, 2009. 6:50 AMalaskanbychoice says:
That was fun and informative, Great instructable. I only have one suggestion and that would be to put a drop of lock-tite or superglue on the second nut you use to keep it from going down any further or you might try fingernail polish.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:pacowarabi
