The main feature of interest is the "J" shaped channel at the end of the pipe. One makes a spear-like thrust with the picker to get the fruit inside the pipe. The stem of the fruit follows through the "J" channel. A twist and pull of the picker put the stem at the end of the "J" slot, where a sharp razor blade cuts it. The fruit falls into the head of the picker.
Alternative ways of mounting the pole will be described.
Remove these ads by
Signing UpStep 1SAFETY WHILE HEATING PVC
Vinyl Chloride, one of the components of PVC, is carcinogenic. When it is locked up in the polymer, however, it is much safer to be around. In my years of experience working with PVC, I have not noticed any adverse effects on my health from being around it.
Always work in areas with good ventilation. If you do get caught in a cloud of smoke, hold your breath and move to clean air.
When heating PVC with a gas stove or propane torch, try not to let it burn. Smoke from burning PVC is bad. With experience one burns it less and less. Don't panic the first time you do burn some. It scorches, but doesn't immediately burst into flame. Move the material away from the flame and try again. Don't breathe the smoke. Smoke avoidance comes naturally for most people.
While heating PVC over a gas flame, keep the plastic an appropriate distance from the flame to avoid scorching the surface before the inside can warm up. It takes time for heat to travel to the center of the material being heated.
Keep the plastic moving, and keep an eye on the state of the plastic. When heated, the PVC material is flexible, like leather. Beyond this stage, you risk scorching it.
A word from James, the plastic engineer -- "Just a word of warning, PVC can handle some high heats but if it catches fire, you wont be able to put it out, it does not need oxygen to burn so don't do this inside".
Another idea from ev372 regarding the heat forming of the bottom in Step 2, "Try dipping the PVC pipe in boiling water in order to soften it. Then fold the bottom fins inward. I used to work for a company that made PVC outdoor furniture and the owner used a water tank with a heating element to soften the PVC pipe and then bend it 90 degrees; worked perfect and no fumes or fire."
I do work inside with the fire technique, but my house is made of cement and has good ventilation. MAKE SURE THAT YOU HAVE GOOD VENTILATION. IF YOU PLAY WITH FIRE, DO SO CAREFULLY.
The big pipe is heavier and harder to maneuver. The idea of the sleeve to conduct the fruit to the ground is an attractive one, but I find it too awkward for large fruit pickers. It works for the light-weight berry picker, though.
Commercial orange pickers here climb the trees, and pick the fruit by hand. They fill a big sack, mouth held open by a ring of rebar, and lower the sack to the ground with a rope.
