Step 5MOUNT THE RAZOR BLADE
You have already gained some experience heating and shaping PVC when you folded the fingers that close the bottom of the pipe. This step calls for more precise heating. You will need a propane torch. Needle nose pliers are also useful, for holding the razor blade during insertion.
I made several of these pickers and modified one of the razor blades to use as a tool for forming all the slits. I ground off the sharp corner of the blade so it would enter the slit more easily, without snagging on the plastic.
After making the slits in the plastic, the plastic will probably have cooled and hardened up again. Bring the local area back up to temperature with the torch. Keep the flame moving to avoid scorching areas.
After the blade is mounted, cover the exposed blade ends with electrical tape to prevent accidental cuts.
4
comments
Add Comment
Thinkenstein (author)
says:
says:
Add Comment
