PVC Glove Drying Stand
290
10
Published
Introduction: PVC Glove Drying Stand
When you come in from shoveling snow your gloves get wet and you want a place to dry them but don't have time to throw them in the drier. Well my mom tried to make a glove stand of her own but it wasn't very successful. So my dad and I decided to make a stronger and more efficient glove stand out of PVC.
Step 1: Tools and Materials
  1. 3/4" PVC cut into the following sizes:
2 - 26" pieces
4- 8" pieces
9- 3 1/2" pieces
8- 8" pieces
2. 3/4" PVC fittings
10 - T's
2 - 90's
12 - Caps
3. Ratcheting PVC cutter (available at home stores) I'm 12 so using the ratcheting cutter made this project much faster, easier, and safer than if I used a saw.
4. PVC Cement and Clear Cleaner
Step 2: Putting It All Togrther
First connect two 8" pieces to a T connector like so and make two of these.
Now connect the two 26" pieces to the piece you have just made to form the legs.
Now connect the rest of your T's to your 3 1/2" pieces and put your two 90's on the ends to make a piece that looks like this. These are the only pieces that you should glue together so that the stand can be taken apart and stored easily. It is a good idea to glue these together one piece at a time and on a flat surface to make that all the T's will point straight up when finished.
Now connect the piece you made two the to legs and make it look like this.
Next take the rest of your 8" pieces and place them in the T's at the top.
Finally put caps on all the open ends and your done.
Step 3: Final Look
After you've finished putting it all together it should look like this.
    • Make it Move Contest
    • Pets Challenge
      Pets Challenge
    2 Comments
    you could add blowing air though the pvc, thus shorting drying time..
