PVC Guitar Stand for Guitar Hero and Rock Band
The Guitar Hero and Rock Band series have given us plenty of music, but they have also given us something else... many plastic guitars in different styles, shapes, and colors. After a while, moving those guitars around all the time gets frustrating and they are always falling over.
After looking through some of the PVC guitar stands here on Instructables I decided to come up with one that had proportions that would fit the game guitars. The best part is that if you have the tools you can make this stand for only around $15.
Before proceeding, a few pieces of advice. First, I recommend dry fitting the entire stand BEFORE gluing it together. PVC cement drys very quickly and if you make a mistake it leaves little time to adjust the parts. Second, when you are ready to glue the stand together make sure you do it in a well ventilated area because the PVC primer and cement give off very strong fumes. Make sure you read all warnings before beginning!
Step 1Parts List
Parts List
Here is what you will need to build this stand:
  • 2 - 10' sections of 1/2" PVC pipe
  • 6 - 1/2" PVC 90-degree connectors
  • 14 - 1/2" PVC end caps (smooth, not threaded)
  • 16 - 1/2" PVC T-connectors
  • PVC primer and cement
  • Some way to cut PVC (hacksaw, miter saw, PVC cutter, etc.)
  • Tape measure or ruler
  • Marker
You should be able to pick up all these items at your local home improvement store. The PVC cement/primer can usually be bought as a set at most home improvement stores. The PVC connectors can be bought individually or in contractor's bags, which will save you a little bit of money.
21 comments
Dec 21, 2010. 1:55 AMskipernicus says:
I made this! It works pretty well, but mine needed one improvement: I added pipe insulation foam on the bottom pipes to keep the guitars from slipping around.
Thanks for this instructable!
Jul 25, 2008. 10:24 AMconor1148 says:
i have a stand like this for my three real guitars, it makes life so much easier since regular stands that only hold one guitar take up so much space
Dec 7, 2010. 3:35 AMscott! says:
I prefer wall hanging because it takes virtually no space, and you canstill view al your guitars easily :D
Apr 2, 2009. 10:01 AMnc2014fan says:
Great instructions!!! I tweaked mine a bit so it could hang on the wall. Added some paint and clear coat and bam!!! Check out the pics
Dec 7, 2010. 3:33 AMscott! says:
Wait? Can't you only play with 2 guitars at a time? Why do you need 5?
Apr 5, 2009. 10:46 PMjgrills says:
Jan 7, 2009. 1:53 AMpirate_monkey says:
Just built this today. Took me two days - one to cut and assemble, then one to re-cut and assemble with glue.
I had to re-cut pieces as my T and L connectors were obviously of larger dimensions, but I think this looks pretty good. Heaps neater than stacking my 3 (probably soon to be 4) guitars against the couch!
Thanks btravis72
my guitar stand
Sep 27, 2008. 7:52 PMCanadarocker says:
Once I move into my new place I might build this, lol Rockband and Guitar Hero makes a small mess
Aug 23, 2008. 10:12 AMBig Bubba says:
cool, 4/5 (i only play guitar hero, but if i had a whole bunch of guitars, i'd make one :D)
Aug 15, 2008. 1:08 AMsoflyforawhiteguy says:
would this same invention work for a real guitar...commment on my page if you want to reply plz
Jul 18, 2008. 9:38 PMGorillazMiko says:
Nice idea! I was planning on making something like this, but was just too lazy to. And I don't have much PVC and I know I'm not going to buy any. Great Instructable, I added it to my Guitar Hero Mods group. +5/5 stars. (added to favorites)
Jul 17, 2008. 10:48 AMBulletbill says:
great instructable! this really, really helped
Jul 17, 2008. 9:45 AMWeissensteinburg says:
Very innovative! You should send this over to them...if there's enough of a demand, they might come out with a series of stands.
Jul 17, 2008. 6:34 AMRetroTechno says:
Good idea! PVC pipe is second only to duct tape as the most useful stuff ever. Do you think this thing would be sturdy enough to hold actual electric guitars? (You Guitar Hero types remember what those are, right? :-)
Jul 16, 2008. 11:40 PMpurduecer says:
A curiosity question: If Guitar Hero/Rock Band require at most 2 guitars...why make a stand that holds 5 or more? Cool idea though, congrats :-)
Jul 17, 2008. 3:20 AMNoodle93 says:
Because he's been forced to use all different controllers from all the different games.
Jul 16, 2008. 11:02 PMMr. Rig It says:
So cool, I was just about to look for something like this, thanks for the posting.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:btravis72
