3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC Guitar Stand for Guitar Hero and Rock Band
Step 7Final Assembly
Final Assembly
This is the easy part. Simply connect the top bar to the base.
Now the fun part: add your guitars! As you can see, this design holds a wide array of guitars. The neck holders make convenient places to store your cords or straps.
You can modify this design to hold fewer/more guitars. You just need to adjust the measurements and buy more/fewer T-connectors and end caps. If you are going to make this any bigger, I would recommend cutting the long bottom pieces in the middle and adding another foot for for support (about where the middle guitar is in the second picture). The PVC tends to sag over time even though the guitars don't weigh much.
Lastly, have fun! Customize your stand and post your results here!
2 comments
Dec 21, 2010. 1:55 AMskipernicus says:
I made this! It works pretty well, but mine needed one improvement: I added pipe insulation foam on the bottom pipes to keep the guitars from slipping around.
Thanks for this instructable!
Jul 17, 2008. 10:48 AMBulletbill says:
great instructable! this really, really helped
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:btravis72
