Step 3: Building the Base
The size of your base will depend on how many notes you choose to use. Mine ended up being a little more than six feet wide. With the two keyboard sections, I created two tiers, placing the one with the sharps and flats on top. For comfortable playing, your bottom tier should be as high as your hand when you have your arm bent at a 90 degree angle. I installed castor wheels on mine to make it more portable, to do this, I had to put 2 2x4's side by side on each side of the base so that there was a wide enough space for the wheels. Where the wheels were placed, it is extended out so the instrument does not easily topple.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
