3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC -- It's Great for Inventions
PVC -- It\
PVC, polyvinyl chloride, is a thermoplastic. It softens with heat and rigidifies when it cools again. While soft, it can be bent and even stretched into molds. Cold, it can be sawed, filed, drilled, scraped, or whittled with a knife.
PVC material can be found at most hardware stores in the form of plumbing pipe. I find it to be inexpensive, especially when I consider all the things that can be done with it -- musical instruments, repairs, tools and toys to name a few.
It is resistant to sunlight damage, has a degree of flexibility, is fairly strong, and is electrically non-conductive.
This is a very valuable material for use in inventions; one that very few people seem to be have experience with.
The picture below shows some of the shapes it is possible to make with PVC.
Step 1Safety while heating PVC
We love plastics for what they do for us, but plastic manufacture and decay tend to pollute the environment and negatively affect our health.
Vinyl Chloride, one of the components of PVC, is carcinogenic. When it is locked up in the polymer, however, it is much safer to be around. In my years of experience working with PVC, I have not noticed any adverse effects on my health from being around it.
Always work in areas with good ventilation. If you do get caught in a cloud of smoke, hold your breath and move to clean air.
When heating PVC with a gas stove or propane torch, try not to let it burn. Smoke from burning PVC is bad. With experience one burns it less and less. Don't panic the first time you do burn some. It scorches, but doesn't immediately burst into flame. Move the material away from the flame and try again. Don't breathe the smoke. Smoke avoidance comes naturally for most people.
While heating PVC over a gas flame, keep the plastic an appropriate distance from the flame to avoid scorching the surface before the inside can warm up. It takes time for heat to travel to the center of the material being heated.
Keep the plastic moving, and keep an eye on the state of the plastic. When heated, the PVC material is flexible, like leather. Beyond this stage, you risk scorching it.
A word from James, the plastic engineer -- "Just a word of warning, PVC can handle some high heats but if it catches fire, you wont be able to put it out, it does not need oxygen to burn so don't do this inside".
I do work inside, but my house is made of cement and has good ventilation. MAKE SURE THAT YOU HAVE GOOD VENTILATION. PLAY WITH FIRE -- CAREFULLY.
93 comments
1-40 of 93next »
Apr 19, 2012. 10:11 PMcart562 says:
I think it was Phil B's instructables i was looking through and one of them consisted of him putting small pieces of pipe in a pyrex cup with water in it and putting in a microwave. It was great for making small, flat pieces and I was just wondering if you have tried using a microwave before. Btw, apparently the newer Pyrex glass may explode from cooling too fast so either experiment with an old one or be cautious when removing it from the microwave for those of you who wish to try it.
Mar 30, 2012. 2:55 PMcart562 says:
So I knew PVC could be used for a lot of things but this is amazing. I might have to start by making some tool handles. I will never ever throw away PVC again.
Jan 23, 2012. 12:08 PMjustjimAZ says:
I have had god success using a heat gun rather than flame. I find it is easier and less likely to burn the PVC too.
Aug 11, 2011. 11:25 AMlilygist says:
How'd you get that flanged end on the knife holder?
Aug 11, 2011. 5:10 PMlilyology says:
Oh I should have been more specific, I meant the thing you called a knife holder, the cup with the flanged end, not the knife handle. Did you press it against something? Can the PVC stretch, or will it just tear?
Aug 12, 2011. 5:17 AMlilyology says:
That's great, I'm going to try to make a curved horn shape out of a 3" tube. I was originally going to either vacuform or cnc fabricate it, but both are complex and expensive processes for a one-shot thing.
Aug 12, 2011. 7:13 PMlilyology says:
I have access to a hossfeld bender, so I'm going to give that a try when I get the chance. For the cone I'm carving out the shape first with a lathe. Not the most instructablesish way to go, but it's a nice luxury. :)
Aug 14, 2011. 5:45 AMlilyology says:
That's a good idea, but it's a bit big. I could use chicken wire and plaster cloth and lay it over with plasteline and then the fiberglass, but that's a hell of a workflow and I want a fairly controlled curve on a budget. The horn is for a sculpture, part of it is based on a megaphone. I'm epoxying this bent pipe to a cheap storebought horn, since I don't think I could make the shape. And I'm a little excited to try working with PVC, it's so cheap(!), stable and durable, and seems pliable enough though I've yet to have a great result. I was hoping that sand alone would work to smooth out some of the bends, but the plastic expands and sand collapses. I imagine it's better than nothing. Definitely need a grooved rig to get a smooth curve, unless you've got another clever suggestion :)
Aug 26, 2011. 12:30 AMjdougherty2 says:
I've never done anything with PVC, but I'd think that it might be a bit easier to fabricate your horn in stages. I.e - heat the PVC and bend it to the curve you want. Then cut it down and heat the PVC again, joining the edges to form your cone. Might be easier, but as I said, I've never done this kind of stuff before. :)
Aug 26, 2011. 12:19 PMjdougherty2 says:
Could you use a jig to bend the curve and then keep it in the jig when you cut it down and make the cone?
Mar 26, 2011. 4:15 AMVinsu says:
Truly inspiring. Now I have some use for all those tools I have with no proper handle/no handle at all. Thank you!
Jan 3, 2011. 3:05 PMfinton says:
Excellent stuff Thinkenstein! I recently discovered the joys of PVC moulding myself and seeing your innovative ideas has fuelled my enthusiasm. I particularly like the high-reach pruners.
Jan 23, 2010. 4:24 PMn0ukf says:
Could we get more info and photos on the boat? How long are the pipes? What is its carrying capacity? Are you planning to do an i'ble on it?
May 26, 2010. 8:27 PMn0ukf says:
Did the (essentially) grooved bottom (between pipes) tend to act like a keel to help stay straight? What was the hard part of rowing? I've been half thinking of trying this but hesitating because of the $10 cost of each 4"x10' S&D pipe available locally.
Nov 11, 2010. 9:58 PMn0ukf says:
Looking more into this, if I make one, I'd use nine 4" S&D instead of the six 6" (maybe SCH40?) for the main raft and pontoons. Also, in Minnesota, unpowered boats 9' or less don't need to be registered. Over 9' or powered do. So I'd be cutting a foot off each 10' pipe. I'd just have to gather up enough money for the pipe (SCH40 is cheaper 100+ miles away than S&D is locally).
Aug 24, 2009. 6:18 AMSSmithers says:
You have just opened up a whole new world for me. I don't have the proper tools to work metal, and sometimes wood just doesn't work. this also appeals to the inner pyromaniac in me!
Aug 23, 2010. 5:42 PMgemtree says:
Oh, great idea. I definitely will stop and ask now.
May 24, 2010. 9:51 PMblowbyblown says:
 can pvc be melted down and poured into a mold though?
Aug 19, 2010. 2:06 PMfishdirt says:
Yeah but it's a high melt. IOW you need a steel die mold. I've been hunting alternatives but can't find any. 350 F is the melt point. You do it in a double boiler pot or with a heat gun until it becomes clear. Another alternative is to buy hot melt vinyl (Vinyl is PVC and vice versa). Vinyl fumes are highly toxic. A safer way, if you have the cash, is smooth on polyurethane resins. It's a soft, rubbery type plastic as well and not as fragile as the acrylic resins.
May 25, 2010. 4:37 PMblowbyblown says:
 well i live on a farm, so i've got plenty of room to not to burn anything down
Sep 5, 2010. 4:11 PMmettaurlover says:
Plastic doesn't continue burning without oxygen in my experience. The only thing that I've had do that to me was thermite and that's because it's supposed to do so.
Sep 5, 2010. 8:44 PMmettaurlover says:
Yeah, though oxidization, by definition, requires oxygen to occur.
1-40 of 93next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
342
Author:Thinkenstein
I'm a refugee from Los Angeles, living in backwoods Puerto Rico for about 35 years now and loving it. I built my own home from discarded nylon fishnet and cement.
