3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC MASSAGE STICK -- for do-it-yourself back massage
You know how you feel and where you hurt better than anyone else can know.  Next time your masseuse is AWOL (unfortunately a chronic situation for a lot of us), get out the stick and fix things yourself.
Muscle spasms feel like hard lumps in the muscle tissue.  You can feel them on another person's back with your finger tips.   Feeling your own muscle spasms with your hands is a bit more awkward, due to their location in back of you.  With the massage stick you can reach them, and work on them to make them go away.
By applying pressure with the massage stick "finger", holding it for a while, releasing pressure, and repeating the cycle several times you can actually relax the muscle spasms.  Eventually, they soften up and stop causing pain.
The PVC pipe is filled with sand, heated and bent to make the bow shape.  The curve makes the stick more comfortable to hold while applying pressure with the finger.
The silicone rubber finger is built around a nail, so it has rigidity for pressing, yet the tip is soft.  It does a great job.  This is something that everybody with a back should know about.
Step 1Safety while heating PVC
We love plastics for what they do for us, but plastic manufacture and decay tend to pollute the environment and negatively affect our health.
Vinyl Chloride, one of the components of PVC, is carcinogenic. When it is locked up in the polymer, however, it is much safer to be around. In my years of experience working with PVC, I have not noticed any adverse effects on my health from being around it.
Always work in areas with good ventilation. If you do get caught in a cloud of smoke, hold your breath and move to clean air.
When heating PVC with a gas stove or propane torch, try not to let it burn. Smoke from burning PVC is bad. With experience one burns it less and less. Don't panic the first time you do burn some. It scorches, but doesn't immediately burst into flame. Move the material away from the flame and try again. Don't breathe the smoke. Smoke avoidance comes naturally for most people.
While heating PVC over a gas flame, keep the plastic an appropriate distance from the flame to avoid scorching the surface before the inside can warm up. It takes time for heat to travel to the center of the material being heated.
Keep the plastic moving, and keep an eye on the state of the plastic. When heated, the PVC material is flexible, like leather. Beyond this stage, you risk scorching it.
A word from James, the plastic engineer -- "Just a word of warning, PVC can handle some high heats but if it catches fire, you wont be able to put it out, it does not need oxygen to burn so don't do this inside".
I do work inside, but my house is made of cement and has good ventilation. MAKE SURE THAT YOU HAVE GOOD VENTILATION. PLAY WITH FIRE -- CAREFULLY.
7 comments
Feb 7, 2011. 10:14 AMpeacenique says:
I believe that technique is called "acupressure". You're right, it certainly works!
Great idea!
Nov 26, 2010. 7:22 AMCreaturiste says:
This is an interesting project!
You can save a lot of time by adding just a tiny bit of corn starch to the silicone caulking. It will set within minutes! Got that tip, and tested it with success, from:
http://www.instructables.com/id/How-To-Make-Your-Own-Sugru-Substitute/step3/Mixing-Oogoo/
Oct 19, 2010. 3:05 PMpiperjon says:
Ah! I wish I'd seen this before I shelled out $30 for a TheraCane. Now, to be fair, I do love my TheraCane, and it works exceptionally well, but DANG, how cool to have done something with my beloved PVC plumbing pipe that could have done the same thing! Awesome 'ible! - Pj
Oct 20, 2010. 4:31 AMKAPITONOVIH says:
Excellent trainer. Perhaps we should use them.
Oct 19, 2010. 7:59 PMnickodemus says:
Nice idea, and I like your technique used when building up the finger - I wouldn't have thought to use a rope.
Oct 19, 2010. 6:15 PMrock crusher says:
good!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
342
Author:Thinkenstein
I'm a refugee from Los Angeles, living in backwoods Puerto Rico for about 35 years now and loving it. I built my own home from discarded nylon fishnet and cement.
