PVC Mjolnir Water Gun
677
15
Posted
Introduction: PVC Mjolnir Water Gun
PVC Challenge
Runner Up in the
PVC Challenge
This will kick your next squirt gun fight up to a 11 out of 10
Step 1:
Cut a piece of 1 1/2 inch thick pvc pipe 16 inches long. This will sere as the shaft of your hammer
Step 2:
For the head of the hammer I used a foam flooring tile.
Step 3:
Cut two pieces of tile 10 inches long and 5 1/4 inches wide. These will become the top and bottom of your hammer
Step 4:
Take one of these pieces and place a 1 1/2 inch pvc pipe cap at the center and cut a hole around it. this will be on top of your hammer
Step 5:
Then make a hole in the other piece and slide it on to the shaft
Step 6:
You will need to cut two 5 by 6 inch pieces and two 6 by 9 3/4 inch pieces
Step 7:
Tape, glue, or staple the pieces onto the shaft, but keep the top piece, you will glue this on later
Step 8:
Drill a hole in your pipe cap for the water to squirt out of.
Step 9:
Glue the cap on the top of your shaft using pvc cement.
Step 10:
Tape or glue the top piece onto your hammer.
Step 11:
Paint the hammer head grey and the shaft brown
Step 12:
Now we'll start on the plunger. Take a 1/2 inch pvc pipe and cut into a 17 inch piece. This will be the shaft of the plunger
Step 13:
Take a 1 1/2 inch pipe cap and drill a hole big enough for the shaft to slide in and glue it on the end. This will serve as a handle
Step 14:
Take a rubber 1 1/2 inch pipe cap and drill a hole in the center and slide it on the shaft
Step 15:
Paint the entire shaft brown
Step 16:
Take a 1/2 inch pipe cap and glue a grommet around it. This will slide into your 1 1/2 inc pipe and cause suction.
Step 17:
Use the pvc cement to connect the plunger onto the top of the shaft
Step 18:
Slide the plunger into the hammer and tighten the rubber pipe cap. Your hammer is now compete
Step 19: Tips
If your hammer doesn't suck up water it probably isn't sealed probably Glue a o-ring around the plunger
If your hammer is too hard to pull out and push in try putting grease on the inside of the shaft
If someone is charging you in a water war don't be afraid to use mjolnir as a hammer
If you don't know how to pronounce mjolnir here's how (Mule-near)
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    3 Comments
    THIS IS THE MOST AMAZING THING I HAVE EVER SEEN!!! YOU SHOULD TOTALLY USE IT IN A CARDBOARD BOAT RACE OR SOMETHING.
    I like it. Does it spray when you hammer something too? It should.
