3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC Rocket Launcher
PVC Rocket Launcher
A few points:
1) This is a rocket launcher without a rocket I will leave it up to the end user to design your own munitions.
2) This device will be considered by many law enforcement agency's as a weapon DO NOT AIM AT ANY THING (other than open sky) I AM NOT LIABLE FOR ANY INJURIES CAUSED BY THE USE OR MISUSE OF THIS DEVICE.
3) I know the title says "PVC" but in the photos the plastic I am using is ABS plastic pipe from the Home Depot.
4) This device is designed to ignite Estes model rocket engines.
5) The launcher costs around 40-50 dollars without the cost of the electronics,wire,etc.
6)I apologize for not taking pictures as this is my first instructable and I had already built this before finding this site.
Step 1Gather all materials
gather all materials
Materials:
1.)-4" flange
2.)-4"-2" hookup
1.)-2" end cap
1.)-4" coupler
2.)- 2' sections of 4" ABS pipe
1.)- roll of electrical tape
1.)- X-acto knife or wire strippers
1.)- 9v battery
1.)- Radio Shack toggle switch with safety cover
1.)- Drill w/ bits
1.)- 7' Speaker wire, I used model the rocket launcher's igniter wire
1.)- hacksaw
1.)- 9v battery snap
70 comments
1-40 of 70next »
Oct 10, 2008. 7:12 AMevanwehrer says:
I have an idea. I could make this, but instead of launching rockets, it could launch nerf footballs with a paintball CO2 tank as a power source, and you could cut the male end of a remote line off to hook it to a pipe.
Oct 10, 2008. 7:20 AMevanwehrer says:
Apr 4, 2011. 9:27 PMMatrix-technician says:
Hey, you may have seen it by now, but there is an "ible" to make an m72-law co2 powered launcher on this site. Just type in co2 m72-law in the search. too lazy to look up the author :)
Dec 17, 2011. 7:38 AMDearden805 says:
That sounds awesome but I can't find it anywhere
Care to look up the author
Dec 17, 2011. 7:24 PMMatrix-technician says:
Hey there! Ok, his name is MrTinkererin, and the project can be found in the graphical search under airsoft m72 law. I apologize, my info was incorrect as it is powered by propane in the shell instead of co2. Propanes volume exspanision is greater than that of other comparable pressurized gasses that's why it's used. But he explains that all in his instructable. Happy building!
Dec 19, 2011. 9:07 AMDearden805 says:
Thanks I appreciate it.
Oct 23, 2008. 2:18 PMwotot2 says:
what are you using to draw that, is it a cad?
Jan 23, 2009. 8:51 PMred-king says:
looks like CAD lite to me...
Jul 4, 2011. 4:42 PMcodycnnn04 says:
Could you use mortar rounds from fireworks?
Jul 19, 2011. 5:10 PMJaycub says:
Have you seen what a mortar does if you light it on the ground? It hardly moves before exploding. It needs to be in a close fitting tube to launch. If you did this it would probably stay in the tube and explode by your head, or if you are lucky it might roll out of the tube and blow up at your feet.
Jul 19, 2011. 5:06 PMJaycub says:
Did you try it?
Dec 15, 2011. 6:46 PMcodycnnn04 says:
No but i see what your saying, but a little idea with the thought of mortar rounds. Have you ever thought of creating a "Noob Tube". Just a thought.
Sep 12, 2009. 1:17 PMThenightmuffin says:
Is the coupler supposed to seal the gun because I can see straight through my gun
May 4, 2010. 9:16 PMgeodez says:
When you are firing a self propelled rocket you want to just have a tube with a handle and ignition because if you cap the end, you will absorb the force of the firing, not have it dissipate out the end.
Apr 4, 2011. 9:22 PMMatrix-technician says:
While that is good for a real launcher, this is designed to fire hobby grade estes model rocket motors. Even the largest E-11 engine is not enough to put any noticable force on you if you were to cap this. Also if you have ever launched a model rocket motor you would know it has a wide area of extremely hot exhaust gasses and sparks, and i would recommend having as much protection as possible from this. I would also advise you add a face shield such as on WWII era tank buster launchers. Or you could just wear goggles and a face mask.
Apr 4, 2011. 10:08 PMgeodez says:
You are not understanding me, what I meant by "force" was the possible melting/fragmentation of the pipe from the sparks, perhaps I should have worded my statement differently.
Apr 5, 2011. 7:01 PMMatrix-technician says:
OK, i see what you mean now. There is absolutely no chance of the pipe exploding, but i would not doubt the rockets ability to melt it if it didn't exit quickly enough.
Apr 7, 2011. 8:37 AMgeodez says:
I've melted some of the lighter-grade ABS when a rocket did not exit the pipe at all.
Apr 11, 2011. 11:37 AMMatrix-technician says:
:) i see. These motors have a bad habbit of reaching temps capable of destroying anything.. ANYTHING... behind them if held in place. I ignited a rocket on a concrete surface and the rocket did not travel up the launch rod and got stuck at the bottom. The concrete actually cracked and exploded outwards because of the heat.
Apr 4, 2011. 9:25 PMMatrix-technician says:
A great way to make this capable of firing an assembled rocket is to add a sabot around the middle of the assembled rocket to hold it level in the launcher tube. Styrofoam should work great, you would just have to cut to fit the rockets body tube. Also make sure the sabot is in 2 half peices, this way it separates and falls off of the rocket when it exits the launcher.
Aug 16, 2010. 4:07 PMDaddio_UK says:
No presure? ever seen a model rocket with a fractured 'charge'? they go off like a bomb!. Be carefull you don't load one like that in, you'll lose 1/2 your face. There is no way to tell if it's fractured, they are rare, only ever had 1 like it, the blast was pretty incredible.
Apr 4, 2011. 9:17 PMMatrix-technician says:
Yes, those are actually quite fun to see explode in mid air. >:) I love a bit extra fire and boom boom when i launch my rockets.
Mar 20, 2008. 11:01 AMmginder says:
DO NOT use ABS plastic, it is microscopically porous and will explode after so many uses. use schedule 40 pressure rated PVC only.
Jul 29, 2008. 4:35 PMPyroManiac96 says:
why not abs? it doesnt need to withstand pressure or anything
Aug 18, 2008. 5:40 PMPyroManiac96 says:
:) i like being right in the eyes of others xD
Jun 22, 2010. 2:31 PMilpug says:
there is completely no pressure. it doesent even need to be glued together.
Jun 25, 2010. 8:07 AMmginder says:
it is not pressure you need to worry about. abs plastic is full of tons of little air bubbles, while making it light weight, it has a low melting point. if you use sch. 40 pipe, it is solid and will not melt after continuous rocket fire.
Jul 8, 2010. 9:33 PMPyroManiac96 says:
I don't think the pipe would be subjected to sufficient heat to burn/melt it to the point where it would effect it structurally- I mean, it might singe it, and it might even heat it to the point where it vaporizes certain chemicals in the ABS that aren't good for you, but it certainly wouldn't be to the point where ABS would be a bad choice for making the launcher.
Jun 22, 2010. 2:35 PMilpug says:
i built something just as good as this for five bucks, but i suppose if you did not have the parts it might be twenty bucks. i might post an ible. Author, do you object?
Jun 22, 2010. 2:29 PMilpug says:
some of these pipe fittings are hard to find. i made something similar to this out of 4" drain pipe. works the same, but has more of a bozooka appearance. it wouls be cool to make one of these based on the halo rocket launcher. you dont need to glue it together so you can break it down. is there a good type of rocket to shoot from this?
Apr 14, 2008. 7:10 AMcrazy4airsoft says:
Hey Rwctt is there anyway you could make an autimatic rocket launcher or mortar for airsoft (like this one but auto) if you could that would be so great! I love the one you made now!!!
Dec 16, 2009. 8:13 PMrufus4938 says:
hey , im new to the site and i was wondering if u wuld like me to put up an automatic version of the rocket launcher?
May 16, 2010. 5:00 PMpyrocord says:
YEEEEEEEEEESSSS!!!!!!
Aug 8, 2008. 4:09 PMphotis22 says:
love it, but could the same thing be done with pvc, is there anything wrong with that?
May 4, 2010. 9:17 PMgeodez says:
Black is cool.
Mar 29, 2010. 6:49 PMwheelscolin says:
check my build out on how to make  a rocket for a rocket launcher
Mar 29, 2010. 6:50 PMwheelscolin says:
Mar 23, 2010. 4:44 PMwheelscolin says:
hey can you send me a list of where to get the supplies mabye send me more detailed instructions
1-40 of 70next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:Rwctt
