loading
Step 2: Cut Section of PVC
Cut Section of PVC to desired length. I just added a half foot to the workpieces that I'll be steaming. My tube came out at about 54 inches.
Sorry No pictures of this one.
SUGGESTIONS:
PVC makes a ton of mess when you cut it. Cut it outside, or over a trash can or something easy to clean up. Also, 4" is alot for a miter saw to handle, so you may have to cut halfway through, and rotate it, cut doesn't have to be perfect, but try you're best.
<p>You can lay the pipe on a flat surface, secure the pipe, then lay a marking device on a 2x cut to the correct height, then drag it down the sides. Both sides will have a mark the same height off the table. <br><br>Next, just measure from one end to mark the spacing for your holes.</p>
Is it possible to steam wood with glued strips? I have a clipboard that I glued wrong and it's warped.
I used a shark steam cleaner as my source of steam.
bending can be used in boat building and also for musical instruments
Why steam wood? Is this used for bending pieces of wood permanently?
This is also good for people who collect surplus rifles. Steam works quite well for removing Cosmoline, a thick petroleum based preservative that is lathered on the surplus firearms before they are stored. It also helps raise various small dents or dings in the wood grains
I know your post is a few years old, but I just saw it. My wife get's angry at me, but when I am restoring a Garand, I stick the stock in the dishwasher on the hot water cycle. Strips it right off!
Yes, its used to make the wood plyable so that it can be shaped to a mold.
A PVC Rope saw would give you a cleaner cut here. They're about 2 dollars at the hardware store. Just chuck the PVC up in something, or make sure it is secured to something. Put the rope saw around the spot where you want to cut it and work it through the piece in a downward motion. A whole lot safer and cleaner than a saw. You also don't risk melting the end of the PVC from the cut.
Good post. Is wood merely soaked or is their actually steam in the box? How do you heat it? You could use a little Lacquer thinner and it will take of all the primer and the black writing written at factory.
I was thinking about doing something like this with a wall paper steamer, nice to know i was on the right track. I had to bend dowel rod for a sculpture project in school and had to use my bath tub, this would have made things much easier.
cool, i'm in the process of making one of these right now. I'm hooking it up to a pressure cooker for the steam. =<sup>)</sup><br/>
oooo cool. i think my dad would like this
About This Instructable
99,172views
100favorites
License:
Bio: I'm a BioMechanical Engineer at Virginia Tech. I consider myself a Do-it-yourselfer, even if it takes more money and more time, I'd rather ... More »
More by sherfy:PVC Steambox to Steam Wood
Add instructable to:
