Introduction: PVC Venturi Vacuum Pump and Radiator Coolant Refill
Picture of PVC Venturi Vacuum Pump and Radiator Coolant Refill
Figure 1
Step 1: Vacuum Gauge Showing Maximum Vacuum Pulled (Vacuum Is 29.92 InHg)
Picture of Vacuum Gauge Showing Maximum Vacuum Pulled (Vacuum Is 29.92 InHg)
Figure 2
Step 2: Venturi Nozzle Simulation
Picture of Venturi Nozzle Simulation
Figure 3
Step 3: PVC Venturi Pump With Air Baffle
Picture of PVC Venturi Pump With Air Baffle
Figure 4
Step 4: Venturi Pump
Picture of Venturi Pump
Figure 5
Step 5: PVC Venturi Pump Schematic
Picture of PVC Venturi Pump Schematic
Figure 6
Step 6: Exhaust Nozzle View
Picture of Exhaust Nozzle View
Figure 7
Step 7: Parts Layout
Picture of Parts Layout
Figure 8
Step 8: Nozzle Assembly
Picture of Nozzle Assembly
Figure 9
Step 9: Exhaust Nozzle Insertion Into Small Diameter Exhaust Tube
Picture of Exhaust Nozzle Insertion Into Small Diameter Exhaust Tube
Figure 10
Step 10: Exhaust Assembly and Nozzle Chamber Allignment
Picture of Exhaust Assembly and Nozzle Chamber Allignment
Figure 11
Step 11: Instructions Part I
Picture of Instructions Part I
Figure 12
Step 12: Instructions Part II
Picture of Instructions Part II
Figure 13
Happymacer (author)2015-07-18
Gosh that's smart! I made a venturi years ago with the idea of spraying liquid fertiliser onto the garden using the reticulation pump. Not sure it ever worked. Maybe I will try this idea.
gwbisho (author)Happymacer2015-07-18
Thanks. You might not need this much vacuum to spray fertilizer. I think it might be easier to use a water siphon technique for fertilizer. However, perhaps I have provided some good ideas.
ringai (author)gwbisho2015-07-21
Learning new cool things you can do is always good information. Seeing how things can fit together to become something new is a great skill.
ringai (author)Happymacer2015-07-20
That's what the fertilizers you screw onto a hose use. Venturi pumps have been used for many decades on board ships for emergency water pumping. When there's battle/fire/explosion damage, it frequently disrupts the power to that section of the ship. The damage control crews use venturi pumps connected to fire hoses to pump out compartments flooded by seawater or fire fighting foam mixes.
There's even a venturi pump backup available for home sump pump systems.
gwbisho (author)ringai2015-07-20
That's what I meant by a water siphon technique. Water is used in a venturi type nozzle to pull in the liquid fertilizer. Siphon is really not the right wording, but that is what they call those devices - venturi siphon.
DIY Hacks and How Tos (author)2015-07-17
Nice project. Thank for sharing.
Thanks. I had a request to post this. It is important to understand that these can be purchased fairly cheaply, but the DIY experience is what makes it worth the time.
About This Instructable
4,471views
46favorites
License:
More by gwbisho:PVC Venturi Vacuum Pump and Radiator Coolant Refill
Add instructable to:
