3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC and Milk Basket Bike Basket
Step 2Measure and cut the PVC
The support for the basket is composed of a simple pair of mounts that screw to the existing hole in the frame by the axel. Most all bikes will have this hole pre drilled. On my bike the fender is attached to it. I obtained a couple of longer bolts from the HW store so that the 3/4" of the PVC could be connected. There are holes drilled through both sides of the pipe.
Cut the pipe so that there is not too much overlap such that the axel bolt gets in the way. Also, you'll need to measure the proper length of height, considering that you will be connecting a "T" to one end.
As you will see, the "T" allows an extended support to run towards the rear of the bike. The diameter of the "T" (and "L") just happens to be the right size to fit in the hole groove of the basket, but not through it. This is key. You'll see this in the next step.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bonedoggie
