My name is Chance, and in this Instructable, I will walk you through the process of making a desk/workbench out of nothing but PVC pipe, pegboard and 550 cord (braided nylon parachute cord). I was given a sort of TV cabinet/3 drawer dresser thingy when I was assigned to my barracks room. I quickly outgrew this and saw the need for something a bit more accommodating for all of my stuff, plus a workspace for my tinkering with electronics. I chose PVC because it is fairly cheap, sturdy and simple. PVC is like a big set of tinker-toys to me! I made it to the dimensions that I did simply because of my needs and the dimensions of my barracks room. You should choose dimensions that best suit your needs. I hope this is helpful to some of you and please keep in mind that this is my first Instructable.
Remove these ads by
Signing UpStep 1Materials and Tools List
5 10' lengths of 1.5 PVC pipe
8 1.5 90 degree connectors
6 1.5 T-connectors
1 4' x 8' sheet of ¼ pegboard
1 6' length of angle iron (1/8 thick) with pre-drilled holes
4 Bolts that will fit through the pegboard holes, with 1 washer and 1 nut each.
PVC primer and cement
2 cans of spray paint (if you only want one color) or 2 cans of one color and 1 can of your secondary color (if you want a color scheme similar to the one that I used).
200' of #550 cord. A different type of cord can be substituted, but make sure it will fit through the pegboard holes before you buy it!
Tools:
A tape measure.
A fine tip permanent marker for marking your cuts.
Either a circular power saw.
Or
A hacksaw with a miter-box for cutting the PVC flush (it's really hard to free-hand) and a handsaw for cutting the pegboard.
Either way, you will need a hack-saw for cutting the angle iron unless you have something else to cut it with.
A paper plate to keep the primer and glue from getting on your floor (yes, I learned the hard way...).
A drop-cloth for painting the PVC pipes and connectors.
4
comments
Add Comment
Add Comment
