3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC and pegboard desk/workbench
Introduction:
My name is Chance, and in this Instructable, I will walk you through the process of making a desk/workbench out of nothing but PVC pipe, pegboard and 550 cord (braided nylon parachute cord). I was given a sort of TV cabinet/3 drawer dresser thingy when I was assigned to my barracks room. I quickly outgrew this and saw the need for something a bit more accommodating for all of my stuff, plus a workspace for my tinkering with electronics. I chose PVC because it is fairly cheap, sturdy and simple. PVC is like a big set of tinker-toys to me! I made it to the dimensions that I did simply because of my needs and the dimensions of my barracks room. You should choose dimensions that best suit your needs. I hope this is helpful to some of you and please keep in mind that this is my first Instructable.
Step 1Materials and Tools List
What you will need to make it to my specifications:
5  10' lengths of 1.5 PVC pipe
8  1.5 90 degree connectors
6  1.5 T-connectors
1  4' x 8' sheet of ¼ pegboard
1  6' length of angle iron (1/8 thick) with pre-drilled holes
4  Bolts that will fit through the pegboard holes, with 1 washer and 1 nut each.
PVC primer and cement
2 cans of spray paint (if you only want one color) or 2 cans of one color and 1 can of your secondary color (if you want a color scheme similar to the one that I used).
200' of #550 cord. A different type of cord can be substituted, but make sure it will fit through the pegboard holes before you buy it!
Tools:
A tape measure.
A fine tip permanent marker for marking your cuts.
Either a circular power saw.
Or
A hacksaw with a miter-box for cutting the PVC flush (it's really hard to free-hand) and a handsaw for cutting the pegboard.
Either way, you will need a hack-saw for cutting the angle iron unless you have something else to cut it with.
A paper plate to keep the primer and glue from getting on your floor (yes, I learned the hard way...).
A drop-cloth for painting the PVC pipes and connectors.
4 comments
Nov 29, 2010. 10:02 AMarawn says:
Man... that's simply what i've been looking for. Perfect.
Apr 25, 2009. 9:05 AMinventorjack says:
Good thinking. When I lived in the barracks, I made a workbench out of wood at the base wood hobby shop, and made it all bolt-together so I could disassemble quickly. The only real problem was that wood is really heavy and cumbersome, and I lived on the third deck. Oh well. Anyway, this looks really sharp. Good stuff! (By the way, where did you get Frank? That's one of my favorite movies.)
Apr 25, 2009. 1:11 PMcamb00 says:
I would recommend a back brace at the bottom but i don't know how sturdy it is with out so
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:redleg8102
