PVC Barreled Crossbowgun
4,358
26
4
Published
Introduction: PVC Barreled Crossbowgun
About: Engineer from the Netherlands. Projects in 3D printing, electronics, prop making, sewing and whatever interests me. (If you have a pressing question go to my site and ask it there. I am way more likely to ...
A video of the crossbowgun I made. it's a crossbow with a barrel that shoots anything you can fit in it's barrel.
it will shoot a 150 gram projectile 60 meters and a bolt 120 meters, actual ammo comming soon.
it is powered by rubber bands and the barrel is made of PVC.
An instructable is now also available:
https://www.instructables.com/id/How-to-make-a-Crossbowgun/
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    hate to double post, but is there a plunger in the pvc pipe, or are the elastic bands in direct contact with the projectile? i would love to see an isntructable.
    there is a plunger of 32mm PVC in contact with the projectile, the barrel is made of 40mm PVC which makes a perfect fit. I used rubber bands because it was way easier to make and i can control the power.
    okay, cool thanks for the pic, it helped alot. i see your point about the rubber bands... might you use surgical tubing instead?
    this is pretty cool. i wanted to make something like this. good job. however, you might get more power if you use an actual bow mechanism to power it, instead of elastic bands. good job.
