iImage Information
this is my PVC pipe Nerf sniper.when i originally made it, it looked like a P-90 but it has evolved since than into this thing. now it looks a bit like an L96-a1 with a famas tactical rail. first of, ammo. u can use anything that fits down the barrel, whether it be a Nerf dart or a clay bullet, i personally prefer Nerf whistler darts because they give awesome range and go down the barrel the smoothest. now moving on to loading and firing. you could either load it like a musket from the muzzle or by pushing the round into the barrel from the back. Also you could take a piece of PVC and fill it with mini marshmallows and put into the back and than blow through that making a full auto marshmallow gun! Here are a few statistics; my best time for loading and firing is 3.4 seconds, it has an accurate range of about 100 ft and only weighs around 1 Lb. plus in all it would cost under 10$, a much more reasonable price than thirty dollar for a Nerf gun that will only shoot like ten feet unmodded.
Also try keep the mouthpiece as a loader and the *thing* under the barrel couldhouse a reciever for an air tank which could pump behind the dart when you use the blower valve.
Additionally if whistlers can fit into your blaster then the barrel is to wide.
it should be 19/32 of an inch
