3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC pipe blades and rotor for HAWT from scrap.
NOTE: This was a proof of concept project, just to show that it is possible to use the casting from an old washing machine to make a rotor, This project is now on hold until I finish my VAWT and other projects I am working on.
I recently had an idea for a horizontal wind turbine.  The idea came to me when I dismantled an old washing machine to get the stainless steel drum to make a patio heater.  I discovered that the drum was mounted on a aluminum casting that had chunky bearings that though would be perfect to make a wind turbine with, the rotor of any turbine is the hardest part of the build and to find some thing this perfect I just had to see if it would work.
I had a 1mtr length of 6" PVC sewer pipe left over from my VAWT  built and decided that i would use it to make a set of blades to see if my idea was valid enough to continue to build a horizontal wind turbine.
For the video the rotor is mounted on a test stand with a clamp.  I already have my brain in gear and a rest of the turbine is already taking shape.
The results speak for themselves, you can see that the blades catch even the slightest breeze.
I may even put my VAWT build on hold for now to work on this turbine as I think it has more potential to get me to the goal of charging batteries for an electric bike project sooner than the VAWT.
I will be continuing work on the turbine and once I have the various stages finished I shall post the Instructables.
Thanks for looking and I hope this gives you some ideas for your own projects.
Andy.
Step 1Marking the pipe
Marking the pipe
The first thing was to mark out the pipe.
I first used a length of angle iron to mark a line along the pipe, by using angle iron you get a perfect line and all your lines will be parallel.
Once the first line was marked i measured the circumference of the pipe and devide it by 3 to give the spacing for the other lines.  I marked the distance on the back of the tape measure so i could wrap the tape around the pipe for a more accurate mark.
Once you have the equal distances marked use the angle to mark a lines.
69 comments
1-40 of 69next »
Aug 9, 2010. 12:41 PMiFirefly says:
Suggestion: Won't your blades be more efficient if the ends are the wider part of the blades? Having the larger width at the center is somewhat of a waste, as the "clean" wind at the outer ends are what drives the blades most, rather than the inner portion, which is "dirty" wind flow interrupted by the hub assembly itself as well as by the inter-blade "wash" affect, all of which combine to make the inwards part of the blades almost useless in terms of thrust potential. That's why some very efficient and simple designs have NO inner blade surface area. I realize that doing it this way could preclude the use of PVC because the skinnier part of the blades won't support their own weight, depending on the type/gauge of the pipe (schedule 40, 80, etc.) I need to get a workshop going...
Jan 17, 2012. 9:14 AMHorsehockey says:
Dr Qui, you have written a very clear, concese, Instructable on your "Experiment". Some of the readers haven't dabbled in a lot of subjects as much as you have.
On the subject of the shape of the blades, you almost hit the nail on the head on your answer above. The real object of the blade, be it powered as in an airplane propeller, or a helicopter rotor, or wind driven like in your blades, is to have the air pressure equal along the length of the blade. The tip speed is greater so it is narrower and flatter, producing X power. As you take power measurements closer to the hub, the blade in that spot is turning slower relative to the wind and the blade is pitched more, thus producing the same power as at the tip. The same is true at all stations along the blade.
Now if I could just find what diameter and thickness of pipe you started with.....!!
Aug 10, 2010. 4:10 PMiFirefly says:
You have a good point; however those designs ar as old as aviation itself - over 100 years. Current technology "tune" every dimension to the projected load, speed and consistency of the wind source. An example of the necessity of using tuned rotors may be found at the Carter Copter site, where they are the first and only to use a slowed rotor with weights on the ends to achieve some amazing results. The leading and edges of their rotors are extended into a delta shape containing the lead weights and the trailing edges have a larger delta (empty of weights) to distribute the Aerodynamic Center toward the end of the rotor blade. The measures of efficiency in this design are demonstrated to be 27 times more efficient than the higher-speed operation. Lower speed+higher mass=efficiency in this case.
Aug 15, 2010. 3:37 PMFreeBaseBuzz says:
That blade is for a autogyro, which is a completely different configuration.
Aug 11, 2010. 10:35 AMiFirefly says:
My inference was to rotor effectiveness in propelling mass and moving air, which is equal in its capacity to be affected by movement of air; an economy of one use infers the other, and most certainly in the case I mentioned (Slowed Rotor). If less movement is required to maintain the same level of energy output, it is more efficient (exponentially, in the SR's X27). As far as your speed=power assertion, I belief Dr. Torque may have a difference of opinion. My motorhome makes maximum torque at only 2300 RPM, yet the best super bikes aren't happy under 9000.
Nov 2, 2010. 1:05 PMbtop says:
Stop twisting everything he says, he clearly said "in power production" nothing to do with combustion engines, another totally different set of principals.
Aug 5, 2010. 9:33 AMsorin0306 says:
how many power can produce with this "turbine" ?
Apr 30, 2011. 9:33 PMsam D says:
Win, doc!
Aug 5, 2010. 10:29 AMsorin0306 says:
what, giga????!!!!!!!!!!!!!!!!!! 1 giga wat = 1000000000 wat is impossible for this turbine, with this dimension to produce so many power .
Mar 31, 2011. 5:45 AMSpaceman Spiff says:
Seriously! Where are you going to find 1.21 jigawatts? The only power source capable of generating 1.21 jigawatts of electricity is a bolt of lightning, Unfortunately, you never know when or where it's ever going to strike!
Aug 9, 2010. 3:35 PMduct tape says:
Failure.
Aug 6, 2010. 1:06 AMtheatre_tech_guru says:
did you ever see back to The future???
Aug 5, 2010. 6:23 PMsorin0306 says:
in really not is possible to use a washing machine part motor for the turbine generator.
Aug 5, 2010. 10:58 AMRetroTechno says:
He is joking, sorin0306. This is a quote from a movie.
Aug 6, 2010. 2:20 AMsorin0306 says:
no no if you use a motor from washing machine for this project you get a unstable output voltage. you can use just a DC motor or a synchronous motor for generate stable output voltage. The motor of a washing machine is asynchrony
Aug 5, 2010. 10:56 AMjumpfroggy says:
http://www.youtube.com/watch?v=mjCRUvX2D0E
Aug 5, 2010. 10:56 AMscraptopower says:
LOL
Aug 6, 2010. 6:18 AMsailorbob says:
Is that your back garden ? Have you ever thought of having a clearout and growing veg. for the family. it would be much more profitable than trying make a windmill
Aug 18, 2010. 4:17 PMmartzsam says:
Haha. He be trollin.
Aug 15, 2010. 6:43 PMRonaldoNZ says:
take a look here for good research details. http://www.thebackshed.com/windmill/Contents.asp and for sorin0306 re: "in really not is possible to use a washing machine part motor for the turbine generator." http://www.thebackshed.com/windmill/fp2a.asp I think 300 watts from a washing machine motor says its very possible, sorry.
Aug 12, 2010. 12:55 PMrichhummel says:
love it!
Aug 7, 2010. 1:10 AMR.Blakely says:
Metal tubing can be used similarly. PVC is not as good for vibrational stress as metal. For example, aluminum irrigation tubing should work instead of PVC.
Aug 7, 2010. 12:51 PMR.Blakely says:
Airplanes are not made of PVC because it is incredibly heavy and quite weak since it fatigues (cracks easily). Scrap aluminum is available at scrap metal dealers. Each blades should have a pivot at its mounting point. Helicopters use such flexible blade mounts to help prevent blade over-stressing.
Aug 11, 2010. 12:17 AMR.Blakely says:
Check out a gyrocopter rotor. Opposite blades are rigidly connected yet both blades can pivot together. This allows the gyrocopter to be safe yet easy to control. Also, aluminum sheet could be used by rolling the sheet first and then cutting the blades out. I have a rolling machine made in Tiawan. Having a rolling machine helps, but you could use the services of a metal working business. Aluminum is almost as easy to cut as PVC. Most importantly, PVC is not safe because it will fail by cracking like glass. This is evident if you use it in winter.
Aug 5, 2010. 12:49 PMdoctoral says:
I love the way your yard is layed out everything is within reach, my dream come true.
Aug 5, 2010. 10:32 PMburwuro says:
I'm a bit confused on how you made the marking/cutting of the pipe. How did you cut it to get that nice curve in the blade? Was it just a bending weight? Thanks
1-40 of 69next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
117
Author:Dr Qui
Currently under no fixed agenda, just going with the flow. All projects are designed to be low cost and to be a simple as possible using recycled and re-purposed materials. Andy.
