3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC pipe blades and rotor for HAWT from scrap.
Step 3Marking and cutting the segments.
marking and cutting the segments.
I marked each of the segments 1 1/2" in at each end and used a chalk line to mark a line along the segment. the chalk line did not show up to good so I used a sharpie marker to redraw the line before cutting.
I was able to use the bandsaw for cutting the segments.
1 comment
Aug 5, 2010. 12:20 PMcchubb says:
Because it's tough to get the line to snap along the length what I do is stretch a piece of twine between the end points then put a quick blast of spray paint along the string. Remove string and cut along the masked line.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
117
Author:Dr Qui
Currently under no fixed agenda, just going with the flow. All projects are designed to be low cost and to be a simple as possible using recycled and re-purposed materials. Andy.
