3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC pipe blades and rotor for HAWT from scrap.
Step 6The bearings.
The bearings.
The bearing casing is moulded into the plastic drum of the washing machine and need to be cut free. you can either smash the tub up or cut it out if you have a use for the rest of the tub.
To remove the bearing case from the tub I used a angle grinder to cut into the segments on the base of the tub, I also did the same on the inside of the tub too.
I then used a a hand axe to hack out the bearing case but not totally destroy the tub, I plan to use the remainder of the tub to make some kind of planter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
117
Author:Dr Qui
Currently under no fixed agenda, just going with the flow. All projects are designed to be low cost and to be a simple as possible using recycled and re-purposed materials. Andy.
