3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PVC pipe blades and rotor for HAWT from scrap.
Step 7Attach the blades and add the bearing cage.
I clamped the blades in position on each arm and drilled the blade for the outermost holes first.
Once all 3 blades where attached I lined up the first blade and drilled the hole for the second bolt.  i then used the the tape measure to make sure the tips of the blades where at equal distances. Once all the blades where set i drilled the rest of the holes and bolted the blades on to the rotor.
I was now able to test the rotor to see if the blades worked. They worked very well, so well that I decided It would be much safer mounted on a test stand than me just holding the bearing casing.
The blades will need some sanding here and there to make them perfectly balanced, I will do this in the tweaking stage before I mount the turbine on a pole.
I hope you like my idea for a scrappy solution to the problem of making a rotor for a wind turbine.
4 comments
Jul 31, 2010. 1:49 AMpleabargain says:
Please post updates when you get it connected to a generator under load! Very clever reuse of 'garbage'!
Aug 6, 2010. 6:32 AMjhampa says:
Sounds great, thanks for the postings. Now I'm looking for a dead washing machine, lol
Aug 5, 2010. 2:42 PMxarlock667 says:
Your inginuity is impressive! Please post updates as you make progress!
Aug 5, 2010. 11:49 AMgogutu says:
Foarte igenios chiar am aceste piese si ma gandeam sa le arunc dar le voi refolosi ,astept sa vedem cu ce vei realiza generatorul de curent,poate va fi ceva simplu si usor de procurat. Foarte igenios
Jul 30, 2010. 10:38 PMdezertdude says:
wouldn't you mount the hub on the motor / generator shaft and not on a bearing?
Aug 5, 2010. 7:14 AMMechEngineerMike says:
a homemade alternator sounds like a nightmare project to me, perhaps you could find an old vacuum or drill motor you could use instead?
Jul 31, 2010. 12:12 AMscraptopower says:
It helps save the generator bearings from premature death, especially if they are not designed to take the kind of forces a windmill might put on them.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
117
Author:Dr Qui
Currently under no fixed agenda, just going with the flow. All projects are designed to be low cost and to be a simple as possible using recycled and re-purposed materials. Andy.
