The heart of the PWM Fan Controller is a PIC 12F675 microcontroller. This microcontroller is reading the analog output of a LM35 temperature sensor using a ADC (analog to digital converter) . The resulting digital value is converted to a temperature and a fan is powered proportionally to how hot the sensor is. The sensor is mounted against the hard drive chassis so it is measuring the actual drive temperature and not just the air temperature inside the housing.
Remove these ads by
Signing UpStep 1PWM Fan Controller - Parts
* Pre-programmed PWM Fan microcontroller
* 0.1 uF Bypass Capacitor
* Blue LED
* 330 Ohm Resistor
* NPN Transistor
* Perfboard
* LM35 Temperature Sensor
I didn't find it here
Click on the first link in the article and you will see the schematic. I didn't post it here since the Instructables resolution would make it non-readable.
