PWM and Frequency Controller (for lasers and diodes)
 by Electo4fun
Featured
Today I will show you how to create a driver for lasers and LED that has independent pots for frequency modulation and duty cycle modulation. The main component of the driver is the 555 Timer IC. View the video to see this driver working. Between pauses I adjust the dials and I used a poor camera so the high frequency couldn't be seen. I try to spin the laser to show the frequency like I did in the picture below.
Step 1: Get the necessary parts!
For this project you will need:
1X  LM555 Timer
1X 220 Ohm resistor
1X 100 Ohm resistor
1X 10K Ohm resistor
3X 100K Potentiometer
1X 100 Ohm Potentiometer (2X if you wan't to have a variable voltage regulator)
1X 0.1uF capacitor
1X 1uF capacitor
1X 0.1uF capacitor
1X 220uF Capacitor
2X LM350 or LM317 Voltage Regulator (the second is optional one is for the voltage regulator and the other for the current regulator)
2X Diodes rated above 2A 10V
1X NPN Transistor (general purpose transistors work for low loads)
1X LED or Laser Diode
Jumper Wire
Breadboard
All of the parts can vary slightly! The diodes can be almost any type and the pots can be any value as well.
elabz says: Dec 6, 2012. 9:49 AM
The pot in series with laser is not a very good idea - pots are usually very low current devices except of course if you use rheostat as a pot[entiometer]. This is the weakest part of pretty much all the constant current laser driver designs based on converted voltage regulators such as LM317.
Also, I'm not sure the switching transistor in the part of the circuit that's after the LM317 will make it a very effective current regulator - may not be safe for the laser during the switching.
If you use base PWM frequency of less than 40kHz (and preferably as low as 10kHz) , I think you may want to look into using a voltage regulator (in current regulating mode of course, just as that LM317)  with a built-in "Enable" function. It will greatly simplify the design and I think will make it more reliable, easier on the laser and will let you use much more powerful lasers, too.  I was able to fit my TTL-controlled (PWM up to 40KHz) laser diode driver onto a 1"x1.25" PCB and it should be able to drive up to 750mA. I haven't tried higher than 250mA  yet but I use it for laser cutting. For laser shows 250mA laser is already a formidable output device. Check out the laser diode driver design here , perhaps it can be useful. Just be sure you design yours not on the LT1121 voltage regulator like I did.  The darn thing is no longer available anywhere. It used to be a $0.30 chip couple years ago and now it's up to $7 each if you can find it. It's sister IC, such as LT1129 , has the same functionality (different package tho) and is still cheap and plentiful, use that one instead.
Cheers!
Electo4fun (author) in reply to elabzDec 6, 2012. 4:16 PM
I do see what you mean about having the transistor after the regulator. Would the regulators still function the same way if they have a pulsed or low duty cycle input? Thank you for your post.
AntzyP says: Dec 6, 2012. 1:50 PM
I tried this out using my arduino few months back. Even implemented in a small project...
Insonicbloom says: Dec 6, 2012. 8:26 AM
nice implementation of the 555 PWM circuit.  I made a stripboard layout for a similar one that Dave Jones put up on his youtube HERE
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
