loading
 a low cost PWM dimmer  using  NE555 and MOSFET  with DIY aluminium case.
Step 1: aluminum case from Aluminum Square Tube.
aluminum case  has dual role.
first one is            protection cover.
and second is    heat sink forMOSFET.
Step 2: Drilling holes
POT fixing on aluminum case.
MOSFET fixing.
Step 3: Circuit diagram
components:
1,  555 ic
2, MOSFET  IRFP510
3, diodes 1N4148 x 2
4, capacitors -ceramic- 100nf ,10nf   47uf/35v
5, Pot  100 K Linear
6, resistor  10K
circuit diagram source:
http://www.talkingelectronics.com/te_interactive_index.html
Step 4: circuit board soldering.
Step 5: final assembly
Step 6: testing with 12V/35W lamp
Step 7: working video
<p>Work!! is easy :)</p>
<p>Hi, the original project and the circuit diagram are in: </p><p><a href="http://www.inventable.eu/2013/04/18/63_led_dimmer_555/" rel="nofollow">http://www.inventable.eu/2013/04/18/63_led_dimmer_...</a></p><p>bye.</p>
About This Instructable
33,895views
73favorites
License:
Bio: embedded system enthusiast ...
More by Jestin_Cubetech:Wireless Robo-car  using  360°  servo motor Raspberry Pi - Revision 2  DIY Add-On Board water tank automation - prototype
Add instructable to:
