Introduction: PacMan and Custom Characters on Arduino With a 16x2 LCD I2C YwRobot LCM1602 IIC V1
Hello everybody, this is my first instructables!
I made this guide because I had a lot of problems to drive the YwRobot LCD I2C with Arduino because of problems related to software libraries.
After much research and testing, at the end, I found some libraries that are compatible and fully working. I have also experimented them using custom characters and so I decided to share my experience with you.
In the end I made a simple animation with a pacman custom charcter that eats all the pills on the lcd...
Step 1: Wiring: Connect LCD to Arduino
there is no need to connect the wires to a breadboard, in fact we will connect them directly to Arduino.
It's quite simple since there are only 4 wires to connect:
Gnd to Gnd
5v to 5v
SDA to SDA
SCL to SCL
see the pictures above for reference
Step 2: Get Libraries and Write Some Custom Characters Code
Download this library and import into your Arduino Ide.
I got this library from DFRobot.com web site.
Step 3: Testing the Display
First of all turn on your Arduino and see the display...
with a screwdriver, adjust the brightness by turning the potetiometer screw on its back, until you will see some boxes.
Into you Arduino Ide open a new Scratch and write the code attached:
this code will displays a simple 2 lines string:
//using DFRobot.com libraries
//Compatible with the Arduino IDE 1.0
//Library version:1.1
#include <Wire.h>
#include <VirtualWire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
void setup(){
  lcd.init();                      // initialize the lcd
  lcd.backlight();
  lcd.home();
  lcd.setCursor(0, 0);
  lcd.print("Hello world...");
  lcd.setCursor(0, 1);
  lcd.print("this is me!");
  while(1);
int backlightState = LOW;
long previousMillis = 0;
long interval = 1000;
void loop(){
//the easiest way to create your own custom character is to create them visually using this web site:
<a href="http://mikeyancey.com/hamcalc/lcd_characters.php" rel="nofollow">http://mikeyancey.com/hamcalc/lcd_characters.php</a>
and then paste the byte array into your Scratch.
Step 4: Writing Simple Pacman Animation Code
Into you Arduino Ide open a new Scratch and write the code attached.
You will see a simple pacman on your display eating all the pills.
GHOSTGAMER44 (author)2017-03-13
now i understand how this works. THANKS! you helped me a LOT!
TomášS18 (author)2015-10-29
Thanks a lot :)
RicardoS20 (author)2015-08-07
Thanks!
RBA2000 (author)2015-07-16
What about:
#include <LiquidCrystal_I2C.h>
rkasemi (author)2015-02-01
error say 'lcd' was not declared in this scope
what is the problem can you give me soultion?
kantona80 (author)rkasemi2015-02-01
It could a problem related to libraries. Did you download the LiquidCrystal_I2Cv1-1.rar
From mine instructables and imported in your arduino IDE?
This is awesome!
About This Instructable
41,307views
33favorites
License:
More by kantona80:PacMan and custom characters on Arduino with a 16x2 LCD I2C YwRobot LCM1602 IIC V1
Add instructable to:
