3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pack Flat Plywood Desk
Recently I was in the market for a new desk.
I wanted to make a desk that was able to be disassembled and packed flat, made from few and easily obtainable supplies with simple tools.
The desk can be created from the following supplies:
1 4'x8'x3/4" A-1 plywood sheet
2 4' 3/8" steel rod
2 3/8" nuts
2 3/8" wingnuts
8 washers
8 screws
Some woodglue
You will need the following tools:
Tape measure
Circular saw (or other saw for making large cuts in the plywood)
Screwdriver
Coping saw (for cutting the notches)
Several clamps
I also recommend a squaring device such as a speed square.
Step 1Create the tops and the sides
Divide the plywood into 4 pieces measuring 2'x4'. You could have the lumber yard do this for you, or use your own tools.
Two of these will be for the top and bottom of the desk and two will be for the sides. I recommend using the smoothest and most regular surface for the top of the desk.
47 comments
1-40 of 47next »
Nov 6, 2010. 11:23 AMmilkbarn says:
Your boards of canada reference is great.
Mar 31, 2008. 12:30 PMDIYhomecenter says:
I had a desk like this but it started bending after 2 years wih a 17 inch old school monitor on it.
Jul 29, 2010. 3:05 PMThe Dark Ninja says:
Hows it holding up now?
Jul 25, 2010. 10:19 AMrapidprototyping says:
why not real wood why not a tressel design table either coffee table or desk
May 16, 2010. 9:04 AMparacord junky says:
nice.  now shove some shallow drawers into those spaces for better storage and to cover the edges.  and you wouldn't have to worry about your pencils rolling away.
May 29, 2009. 5:14 PMstephenniall says:
wow very nice and simple
Dec 20, 2008. 4:05 AMacornman says:
Carry the box - tab idea further... make another box section exactly the same as the desk top but a third of the depth (narrower) .cut a tab to the width of the new box at the bottom rear of both side legs with spacing either side . The sides are then dropped into the new box at the back.Now you have tied the sides together without the rods and provided a foot rest at the same time, also assembly and disassembly now require no tools!
Nov 30, 2008. 3:04 AMjosiahkerley says:
You know, if you're having a problem filing, you may want to invest in some quality files. I used a set of stanley's for years, then I use a friends Rockley's, and it was like a torch through butter.
Jul 6, 2008. 6:26 PMneuralstatic says:
you were talking about the pain of filing... would a belt sander help here to grind away that excess from the cut?
Jan 26, 2008. 7:27 PMursus57 says:
Great quick and storable item-some one will steal this and patent it. Will build, for the grand brats.
Jan 22, 2008. 11:32 PMcsmithblues says:
my only question is this: is there any advantage to having the leg tabs "hover" over the surface of the desk? Fantastic instructable by the way.
Jan 10, 2008. 7:18 PMAmir says:
Before I saw this, I thought that I had a desk that couldn't be improved on. -It's a piece of melamine spanning a gap between two small filing cabinets. but not only does yours look really cool, it's got storage. I love it.
Dec 31, 2007. 9:09 AMmacdadyabc says:
thats a pretty good design. i did a project like this a month ago, but instead, i mounted a peice of mdf to a wall with hinges, and two legs on hinges as well. so i just lift it up, and it only sticks out about an inch or two. its nice to see other ways of thinking
Jan 8, 2008. 4:50 PMmacdadyabc says:
more or less, yah. mine has two legs ,though, instead of a drawbridge-type- suspension. same basic idea
Jan 3, 2008. 1:32 PMXamu says:
I have a recommendation or 2 which will make your desk very much more stable.
1) Instead of using a nut and washer on the threaded rod in between the legs to hold the legs apart, carefully measure the distance between the legs for each rod and cut a piece of 1½" (or thereabouts) PVC plumbing pipe. It is important to cut the ends squarely so you might want to buy an inexpensive miter box. (That will also help you practice with your Japanese hand saw.) Another related trick is to wrap a piece of stiff paper around the pipe until the edge of paper is straight and then you are guaranteed to draw a perfectly square line around the pipe.
After you have the pipe cut to length, slide the rod through the leg, the pipe, and through the other leg. Instead of using the washers and wingnuts, use the washers and regular nuts.
Make sure that the pipe is absolutely square to both of the legs (using your speedsquare) before tightening with a wrench. With 3/8 threaded rod you should be able to really tighten those suckers good.
I recommend that you place one of your PVC encased rods half-way up from the floor along the back of the desk (which I see you have done). A second PVC encased rod can/should be placed much lower and a bit more toward the front (like 6-12" from the back) so, in addition to stability, it can also act as a footrest. (Having the second rod right under the desktop doesn't make the desk very much more stable. By taking it out of the same plane of the rod on the back, you minimize the parallelogram racking stresses. It will also make the desk much more comfortable to use. You might need to do some trial and error to find the most comfortable footrest position but I'm guessing that 5-6" off the ground will be best.
2) You were left with four squares of scrap plywood from when you cut the tongues for the legs. Take one (you actually may need two depending on how straight you saw) of those squares and cut it on the diagonal (make sure one triangular piece has 2 factory edges - not 2 triangular pieces with 1 factory edge each). These will become gussets to strengthen the joint where the leg meets the bottom of the table top. Use the factory edge whenever possible. If the sides of the waste piece you cut (to make the tongues) are not square, don't sweat it. Just get another square waste piece, cut on the diagonal (as above) and use the factory
Pre-drill all holes and screw the gussets about 2-4 inches in from the back of the desk. Why? Two reasons - 1) having the gussets in more means you are stabilizing more of the leg. 2) You might want to put a clamp on the corner and you'll need the overhang so the clamp can grab.
Jan 4, 2008. 7:33 AMXamu says:
Sorry, didn't mean to imply your design wasn't very sturdy. You have a very innovative design that applies forces very differently than most furniture. What's cool about it is that the threaded rods can either pinch-grip the top by moving the inside nuts outward (rod compression) -or- the threaded rods can push outward against the outside edges of the top by moving the inside nuts inward (rod tension). But all that force is concentrated at the back of the desk (which isn't ideal). So, it would probably be beneficial to have some additional bracing. Ironically, you have leveraged (literally) a weakness of the design (long thin legs) into a strength by turning them into levers. I can't tell if the fulcrum is the point where the leg meets the desk or where the top threaded rod meets the leg - I'm guessing the former. Bottom line, your desk should give you good service for quite some time. Good job!
Jan 4, 2008. 6:57 AMWade Tarzia says:
Nice! I like the storage niches underneath. Are the plywood side 'legs' a little wobbly?
Jan 2, 2008. 7:15 AMtexastiger says:
Thumbs up for a simple build for a very usefull piece of furniture / workspace. One suggestion would be to cut a square panel out of the bottoms of both legs. This would reduce weight, give you some raw material for another project or for the scrap pile and would not affect the stability of the desk.
Jan 2, 2008. 10:45 AMjh_cirque says:
Nice build. Noticed that you use Festool equipment. How do you like them? Considering buying a few pieces for an upcoming project. Are they worth the premium cost? Like the small form factor since I have no space to store larger pieces. Thanks.
Jan 2, 2008. 7:12 AMpikwitonei says:
Nice Festool shop
Dec 31, 2007. 6:48 PMDrStoooopid says:
nice build, I might have to put one of these together.
Dec 31, 2007. 9:04 AMsickdog74 says:
Very nice, I might have to build this!
Dec 30, 2007. 11:34 PMVidek says:
Nice desk, have to say I like the idea for the legs and the peg at the top. Wanted to say though, you would have a easier time filing the wood with a rasp, basically a woodworker's file, the one shown in your picture is made typically for metal and used occasionally for plastic. Good job though!
Dec 30, 2007. 3:50 PMAustringer says:
Nice. If one were inclined you could dress this up with things like iron on edge banding or take it all kinds of places artistically with a jig saw. I was going to echo Zzag's suggestion about crossing the streams, er, wires but since he did, I won't. Cool stuff.
Dec 24, 2007. 9:12 PMbekathwia says:
Boards of Canada, hah!
Dec 30, 2007. 2:11 PMJustAnotherDave says:
We're doing obscure BOC refs? Then I say music has the rights to children, who have rights to pack-flat desks. Which gets me thinking... This is actually a pretty cool kids' project, seems like. Save having to get different desks as they grow; just make different uprights. And if they're old enough, this seems like one they could do themselves with supervision, or they could mark the measurements in pencil and have Mom and Dad do the sawing.
Dec 30, 2007. 2:12 PMJustAnotherDave says:
That should be "right" to children. I'm apparently thinking in copyright terms.
Dec 25, 2007. 7:47 AMmaruawe says:
this works well but I had a problem with movement. to solve this I notched the uprights six inches from the floor and three inches from the edge, I made a four inch cut 3/8 wide and 4inches wide I inserted another piece of 3/8 plywood to protrude 2 inches drilled a 5/8 hole and inserted a 5/8 dowl rod. This back piece made it sturdy enough to put some heavy laser products on the desk. Hope that this works for you also
Dec 30, 2007. 9:42 AMzzag says:
Nice design. I would guess some of the movement is there because the design is a parallelogram (the only stability is the thickness of the sandwich putting a coupling force on the legs). If the parallel rods were arranged in an X-shape instead, the movement would be reduced. And if the plywood is stiff enough, the 'X' doesn't necessarily have to be made of rods. E.g. could be rope with turnbuckles. Separate as much as possible, running diagonal from sandwich to floor.
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:drocko
I'm an engineer (apparently) that specializes in media based computer systems and large storage (Terabytes). I went to school for painting and I like to make things.
