When I saw the picture on the internet, I thought, well... that shouldn't be so hard to make it my self and dove into the adventure of designing, creating and (for the first time) doing upholstry. I hope you like it and comments/suggestions are welcome...
(please forgive me my poor choice of english words or typos in this instructable, but I think the general idea is there...)
Remove these ads by
Signing UpStep 1Design
First thing I always do when I start a build or a project, I create some Autocad drawings on scale, so in later stage during the build, I can easily measure the angles and sizes of the woodwork I need.
The requirements for the design I constricted myself to:
- low cost (was about €120)
- low weight
- easy to build
- sturdy (should be able to hold 2 people at least)
- in metrics (of course, it is the world standard!)
Then the following process was to determine the size of the pacman:
- for the height I took my current couch as the best height (40 cm). Keep in mind that the foam/padding determines the height of the woodwork!
- the radius of the pacman was defined in proportion with the height. It looks quite large (d=80 cm) but proportionally the pacman will look strange if the height (40cm) was set to a 50 cm diameter.
Material list:
- 15 mm MDF, depending on the size, you will need at least the C-shape to be created from one piece.
- 9 mm multiplex (plywood)
- 32mm*40mm timber (count number needed * height for total length needed)
- larger ones (for example 40mm*40mm) for the corners and block
- upholstry. I used sky to get that leather-look, but it is not so flexible. Mine had already some sliding-stuff on the inside, so it can slide over the foam. If you get other stuff, inform if you need additional stuff.
- cardboard strips. I had special ones, but you can cut some yourself
- staples.... lots!
Equipment needed
- workmate / bench
- Jigsaw
- drill
- drill-bits
- countersink
- screws (about 30mm in length, 3,2*30mm would be ok)
- wood glue (read instructions!)
- needle (curved one special for this type of work) and thread (special stirdy one!)
- sewing machine [if available] (I don't know if a regular sewing machine is able to get through the upholstry)
- foam and other filling
- a stapler! (I had a pneumatic one, but an electrical or whatever is a must... I don't thing the manual ones will be able to enter the MDF deep enough).
- knive
- markers
! Tips / Remarks
In the design the top (9mm multiplex/plywood) of the pacman was created seperately because I was not certain if the upholstry required a top that was not connected. Only when doing the upholstry I found out that it was better that the top was fixed but also for the weight reduction it is a good solution!
Loving it!
Ik heb een vraagje. Wat is die rode bekleding voor een materiaal?
Heb het gehaald bij een stoffenhandel op de Albert Cuyp.
Het nadeel van skai is dat het niet heel rekbaar is, wat het moeilijker maakt om scherpere hoeken zonder 'kreukels' te krijgen. Met echt leer zou dat beter gaan...
What ever floats your boat!
second i thought id quickly change your picture in photoshop to see if it would look just as good in his actual colour, your comment about "depends what glasses your looking through" doesnt really make any sense but whatever...here it is if anyone wants to look...
If you Google for some of the original pics, you will see some other color combinations as well...
Good luck in creating! please link your project!
1 "Footstools" are usually smaller than ottomans.
2 Archaic. Found mosty in poetry & traditional rhymes.
3 Most commonly accepted English spelling.
a Informal slang for "buttocks." (See also: patootey, kiester, duff, hiney, hind end, backside, butt, bum, bottom, posterior, sit-upon... there are many more.)
Example use: "I parked my patoot on that really gorgeous Pacman pouffe." :)
(Sorry if this is more than you wanted to know - I have way too much fun with the complexities of English, and can get carried away sometimes.)
(see http://translate.google.com/translate?prev=hp&hl=en&js=y&u=http://nl.wikipedia.org/wiki/Poef&sl=nl&tl=en&history_state0=)
