Paint Thinner Jar Rack
1,533
26
Posted in WorkshopTools
Introduction: Paint Thinner Jar Rack
About: That's what I do. I drink, and I know things.
This is a rack made of wood that holds three jars of paint thinner.  The top is screwed between two pieces of 3/4 inch plywood with wood screws.  The tops have been cut with a hole cutter so that the jar slides exactly up to the ring.  See the photos for the ring and how it fits on the unit.  I measured this with calipers.  The jars are pint-size wide-mouthed mason jars.
Use is straightforward.  The first cleaning is in the left-most jar.  After using a paint brush comb put it in the middle jar and then finally the right most jar.  As you use them, the left most jar will become the most soiled.  When it is really soiled, discard it and move all the jars one slot to the left.  Clean and refill the soiled jar and it now becomes the right-most jar.  So essentially you always have a jar that is almost pristine.  This helps really keep your brushes clean.  I've found that if I can let the jar settle for a week that the solids fall to the bottom and then I can pour the paint thinner thru a filter and reuse most of it indefinitely.
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    3 Comments
    Nice work! I have a few jars of paint thinner in my shop that I try to rotate through just like you explain here. But this holder makes the whole idea much more controlled and efficient. I just eyeball which jar of mine looks the dirtiest and start there--I have to make one of these! Thanks for the great idea.
    excellent! I do this for paint thinner and adhesives its stops them falling over and makes them safer to handle.
    Absolutely. Especially will paint brushes and thinner. The brush handle is like a lever. Easy to tip over the jar without a base. Thanks for the comment.
