Pretty Simple (as long as you have a *3D printer) Feel free to scale them up and probably have to change your media at 1 gallon and above.
I used a Thing-o-matic MakerBot with a Stepstruder MK7 to print the adapter.
I'm stirring 33oz batches of Plaster of Paris to make a baking template for a plastics component of an invention that will be going up here soon as well.
I made my STL file then scaled it to 10 to get the best blend between size potential and the right amount of strength to withstand the torque from the drill.
I was going to just use a rod and tap a hole in it, or even salvage an old electric beater head, trim the whisk parts off and just make it work as a drill bit that way.
I thought: you know if I can make the head in Inventor, I can make the bit adapter in Inventor too!
So I did.
First I made it so the whole part was laying on the XY.
Upon seeing the disparity between the top and bottom I thought I was going to have to build it vertically.
10% through I was sure it wasn't going to work because of the distance I was lofting.
Much to my surprise it got handled with very little detail loss. I did have to file it a touch (in step II), but in the end I was quite happy that I let the job keep running.
NOTE: The 'Plaster of Paris' was way more viscous than I thought. It was actually like concrete. I'm sure the head will hold up to this, but the drill was far too weak to support it. So, being a true martyr, the bit went ahead and broke off to save the drill's life. In short "Make your bit out of metal if you're working with anything of a higher viscosity than oil based paint. So since you want this to last you should probably do that anyway. I'll leave the bit STL up though.
Remove these ads by
Signing UpStep 1Gatherous up all ye parts
OR
You can build it then hunt for the parts that will allow you to use the printed head. I made it at TechShop SF so I have the advantage of being able to scrap hunt from leftovers that other makers have left in bins after they finished their projects.
How about www.replicator.com?
Then those of us who are trying to make do with our regular hand tools can still find useful things to do, such as pfred2's suggestion, is far more useful than "print this with your 3d printer".
You'll have a few motors and some control switches with cool LED lights for your Aluminum Rubik's Cube Robot.
We are early adopters. Not to make it a tit-for-tat or "be argumentative." Actually it is in my nature to be that way, so what I'm really saying is please take this the right way.
Once upon a time, a Credit Card, a 2D printer, A computer itself, a Fax machine, a TV etc... were all things that most people would scoff if they were expected to have handy as a resource.
In my humble opinion - if you don't have a 3D printer that can turn trash into new tangibles on your desk in 10 years, I'll be shocked. We throw away 270,000,000 of the 300,000,000 used tires we produce every year in this country. Vulcanized Rubber can be ground up and mixed with foam additives to make any 3D printout you can imagine. A single tire could make a closet full of useful things for your home, yard, life......
That's my $0.02
You just can't beat a corded drill for real power.
