3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paintball Grenades
Paintball Grenades
Re usable, cheap paintball grenades and are easy to make
Step 1Materials
Materials
1.Sergical tubing (I got mine from a friend who was in physio tharapy and my brother got some also from a physio tharapist but im sure theirs other places to get it)
2. Coat hanger (straightened out)
3. Air soft BBs (the 6mm ones, it shouldn't matter what weight)
4.Paintballs
5.Water gun pump(out of the gun). Iv also used nerf gun peices but their harder to use.
217 comments
1-40 of 217next »
Jan 6, 2009. 3:08 PMacrafty says:
wat type of not is good???? cause hard for me doing a simple water ballon knot
Apr 16, 2012. 7:13 PMJarheadicus says:
Correction: It is called an overhand knot.
Apr 1, 2012. 2:41 PMRock76222 says:
So, if I were to pull the pin and put this grenade in a rocket launcher that fires it across my yard at high velocity, will it keep from exploding until it hits it's target, or will it burst inside my launcher the moment i pull the trigger
Jul 22, 2011. 9:53 AMNE patsrock says:
ya a vid would be nice
Jul 25, 2011. 6:59 AMNE patsrock says:
o
Jun 18, 2011. 9:44 AMpbman123 says:
do you have any idea what wall thickness you used or does it not matter
Jun 7, 2011. 8:46 AMpbman123 says:
where do you get the tubing. and also could you add a video so i can see how well it works?
Feb 14, 2007. 3:53 PMrocketdork says:
wher els can i get this toob josh
Feb 16, 2011. 2:33 PMrockadio101 says:
kinny drugs its colled a comdom
Nov 10, 2009. 2:07 PMManchesterUtd. says:
home depot or lowes
Nov 11, 2009. 4:54 PMManchesterUtd. says:
Oh, well i dont know what to say. i got mine at home depot
Jun 26, 2008. 1:36 PMcodongolev says:
you could use a balloon. (the long thin kind)
Apr 8, 2010. 5:34 AMnaruto the ninja13 says:
why?
Jul 22, 2008. 4:50 PMcodongolev says:
ummm..... okay.
Feb 6, 2011. 8:36 AMtheREALcybercat says:
Iis this could work with water as well as paint?
Jan 15, 2011. 10:21 AMHitman227 says:
ritter4242 copied this instructable but they both(the grenade) are built the same. Good job!
Jan 23, 2011. 8:08 AMHitman227 says:
Yes it is. d:p
Mar 27, 2010. 7:12 PMdjlolypop says:
i when u use it pick the stuff up and make like a good place to put it in then when u get back home make more
Dec 24, 2010. 1:10 PMspenfisher12 says:
what does your comment mean
Oct 30, 2010. 7:11 AMcam.dav32 says:
Could you use a bikes inner tube for the tubing?
Oct 7, 2010. 2:22 PMjohn209 says:
what diameter is the tubing?
Jul 28, 2010. 6:00 PMmigel says:
you can get surgical tubing at most hardware stores
May 20, 2010. 8:44 AMwectangle says:
the other advantage to using the surgical tube is its shape. you should be able to put one in your ammo pod to protect it when out in the field...
Jul 10, 2007. 1:41 AMtommyskater1 says:
what kind of tubing do you use?
Sep 14, 2009. 5:55 AMswitchpaw says:
between 20 and 16 gauge wire works for the pins.
1-40 of 217next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Prop
