3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paintball Grenades
Step 10How to use it
How to use it
To use the grenade carefully pull out the safety pin and throw. What should happen is when the pin is in any extra pressure in the grenade pushing against the BB (like the pressure from dropping it or bumping it while running) will try to push the BB out but the pin will stop the BB. When you remove the pin, as long as your carefull the BB will stay in the neck of the grenade and the collar will help it stay there. When the grenade hits something the extra pressure will push the BB out and the paint will be sprayed every where in the area. The pressure for tube will cause the grenade to spin so the paint should sray all around. If you keep the pin and find the empty grenade you can re-fill it, put a new BB in and you can re use it. The splatter zone (area that the paint covers) varies but is usally around or over 1.5 meters. Have fun!
15 comments
Jun 7, 2011. 8:46 AMpbman123 says:
where do you get the tubing. and also could you add a video so i can see how well it works?
Mar 27, 2010. 7:12 PMdjlolypop says:
i when u use it pick the stuff up and make like a good place to put it in then when u get back home make more
Dec 24, 2010. 1:10 PMspenfisher12 says:
what does your comment mean
May 20, 2010. 8:44 AMwectangle says:
the other advantage to using the surgical tube is its shape. you should be able to put one in your ammo pod to protect it when out in the field...
Apr 25, 2008. 11:33 AMSofa King57 says:
got everything but the pump how do you do it with a nerf gun?
Mar 1, 2008. 4:46 PMnutsabouteverything says:
i think i gonna try it but idk, i think it needs to be alot bigger. bigger is better!
Jun 22, 2007. 6:43 PMjust blow stuff up says:
why not a water balloon filled with paint?
Feb 19, 2008. 7:21 PMvenus says:
becuase it gets dirty
Feb 10, 2008. 6:36 PMblackspeed says:
W.O.W !
Jun 23, 2007. 10:25 AMjust blow stuff up says:
true....... and it would be hard to hit someone anyways. instead of just throwing it at some people and watching paint splatter everywhere
Mar 30, 2007. 5:56 PMrocketbat says:
hmmmm, sounds like a great way to paint a room!
Oct 3, 2006. 5:43 PMcyfer8 says:
wow thats cool i should try it one day
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Prop
